New Option for PCCB Replacement Rotors
Came across these. I am sure the makeup of the rotors are not the same as OE but it is another option. I do not know if they are putting a spin on the name since iron naturally has carbon in it? What are your thoughts?
Front and Rear are available for about a $1k each
Replacement CERAMIC HTCIC (High-Tech-Cast-Iron-Carbon) Brake Disc rotor. Porsche 997 Models
Front
Size: 380mm x 34mm
Weight: 8.9 kg
Rear
Size: 350mm x 28mm
Weight: 4.6 kg
• Simple to change
• extreme high fading level
• high thermal stability
• HTCIC (High-Tech-Cast-Iron-Carbon)
• optimized for all Series- and
Sport brake-Pads from Porsche
Fits:
Porsche 997 GT3 FRONT
Porsche 997 GT3RS FRONT
Porsche 997 TURBO FRONT
Porsche 997 Carrera FRONT
Porsche 997 GT2 FRONT
These Ceramic Brake disc are to be used with the original Porsche center bells /hat. An extra brake disc nuts and bolts fitting kit is available on request.
http://www.design911.co.uk/fu/pt66_202_-cma81-cmo117/Porsche/997-MKI--911--2005--/Brake-disc/
Front
Size: 380mm x 34mm
Weight: 8.9 kg
Rear
Size: 350mm x 28mm
Weight: 4.6 kg
• Simple to change
Fits:
The answer to your question is in the original post, it is even in bold type captain obvious
Jul 29, 2019 11:13 AM
turbosonoma
Aug 19, 2015 02:05 PM
