Launch techniques with tiptronic
Old Apr 29, 2010 | 03:24 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Originally Posted by milou
The tiptronic might fail any time or might be abused an never fail. In my case i never ever did any brake launches since i could do 3,1sec 0-100 runs.
But on a car with modded VTG's as another member said, for the tiptronic to fail its a matter of time.
I thought you had modded VTGs...So your tip might fail...
Old Apr 29, 2010 | 04:11 AM
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
Till now everything on my side is runing perfect, my car did pass 75k
I start using this method when it was 2000 after the break in and still doing that without any problems
Old Apr 29, 2010 | 04:54 AM
How many times per month?
Old Apr 29, 2010 | 07:21 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
My tip was sliping that is why i have send it to MKB for upgrade
Old Apr 29, 2010 | 09:08 AM
What is the cost/power handling of the upgrade?
Old Apr 29, 2010 | 09:33 AM
milou's Avatar
cost is 3,950 + VAT.
Then the gearbox can handle upto 1300nm/tq
Old Apr 29, 2010 | 09:41 AM
What about clutches?Can they stand many break launches?
Old Apr 29, 2010 | 09:48 AM
milou's Avatar
The technitian is a Greek guy called Panos, i can give you his contact information if you want to.
Yes they add discs change the valve and some other staff that he didn't want to publish.
For sure they know best at MKB, since they do Merc cars and they know which parts are best to use.
I have created a thread if you want to know more i'll post everything i went and will go threw
https://www.6speedonline.com/forums/...ade-movie.html
Old Apr 29, 2010 | 09:59 AM
Good info...
milou's Avatar
MKB does not guarantee you that you can be doing brake launches all the time. But for sure it will handle better than the stock. Some people have upgraded their transmitions and then brake them, because thei thought they became bulletfroof.
Its the same when you add a racing clutch on a MT modded car, if you do hard launches all the time you might brake the flywheel, an axle etc.
In my case i didn't upgrade to do brake launches, but because my tip was spinning between 3rd to 4th gear changes
7thsign
Dec 12, 2015 07:43 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
alpha motoring
Oct 2, 2015 12:04 PM
