idle Problem ... help please
Old Jun 2, 2010 | 01:36 PM
k_ddsl's Avatar
k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !
Tell me when and where... I'll come see you...
Old Jun 2, 2010 | 01:40 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
okik bro i will ,, hope i can fix the car
Old Jun 2, 2010 | 01:45 PM
k_ddsl's Avatar
Hope so bro...
Call me anyway...
Old Jun 3, 2010 | 05:00 PM
ysfg35's Avatar
we fixed all the leaks ... but still the same problem .. idle still playing
The thing that makes me wonder, the car suddenly runs normal ... no problems
when i just press the gas and run hard then run normal after ,, idle plays again when am stopped!!!!
its look like the car Do not breathe,,, run 5 mins in normal drive everything back fine ,, its look like the car act crazy
Old Jun 3, 2010 | 05:02 PM
vividracing's Avatar
Does it only hunt for idle on start up after cold or every time you come to a stop or push the clutch in? Check those Forge Valves you installed to see if the piston is sticking open.
Old Jun 3, 2010 | 05:07 PM
ysfg35's Avatar
not eveytime ,, just when the car cold and after run it hardly ...
what make me feel crazy that after mins in normal drive everything back normal !!!
i will see the valves Tomorrow
Old Jun 3, 2010 | 05:11 PM
takes 30 seconds then idles normal right? cold start only?
Old Jun 3, 2010 | 05:17 PM
ysfg35's Avatar
yes ,, but not only in cold start ,, its also when i run it hard to race idle back plays .... then 5 mins later or less it back fine !!!
Old Jun 3, 2010 | 05:43 PM
sticking blow off valve. pull off the forge and grease the piston. check the fitting that goes on to the air filter on the driver side above the intercooler for the secondary return pump.
Old Jun 3, 2010 | 05:45 PM
ysfg35's Avatar
we scan everything and fix all leaks .. i will try replace the DVS with the old blow off and let you know
thanks for your support
Old Jun 3, 2010 | 06:21 PM
sounds good.
Old Jun 4, 2010 | 03:36 PM
Serpentene's Avatar
Serpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant future
did you not say huge crack in exhaust headers???
Old Jun 4, 2010 | 04:44 PM
FLT6SPD's Avatar
FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !
That picture looks like you have some leaky seals on the turbos as well, it should not be that wet looking.
You get any pics of the cracked headers?
Hope you get it sorted out.
Originally Posted by ysfg35
after checkin the car we found alot of leaks
here is leak in the intercooler hose which connected with the turbo ...
and a big crack in the headers huge in fact , i forget to get a pic but i will
yousef
Old Jun 4, 2010 | 05:03 PM
he does not have cracked headers. he has a brand new set actually.
Old Jun 8, 2010 | 05:25 AM
ysfg35's Avatar
Problem solved ...
it was the dvs .. i changed them and the car fine
thanks dan for the support
