My data-log numbers
Old Aug 5, 2010 | 10:09 AM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
Protomotive is good and Todd is awsome to deal with.
Old Aug 5, 2010 | 10:42 AM
AlexM's Avatar
AlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant future
What tool did you use to get that data off your car?
Old Aug 5, 2010 | 10:50 AM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
I used Durametric to data-log.
Abby I have reached out to Todd for his E85 Tune on OEM fueling system, he is out of town till Monday.
Old Aug 5, 2010 | 11:58 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by venkatreddytx
I will put MS109 race gas today and datalog.
LA8Apex link on "Technical Data On Flashes" is a real eye opener, thanks.
TTDude have been able to datalog? and does your timing look good on Protomotive tune?
Here's a comparable log. Load is fairly high, running ~1.5 bar boost. Timing holds steady, afr's are nice and safe, this is a pump tune.
Old Aug 9, 2010 | 07:24 PM
Approached Todd/Protomotive to resolve my timing issues, plus to get an E85 Tune.
Spoke to Todd this morning on getting a 93 tune and a E85 tune with stock(60 lbs) injectors.
After further discussion we decided to upgrade to 5 Bar FPR as the only mod replacing the stock 3.8 Bar FPR.
This should be an easy install that I should be able to do, any pointers/tips appreciated.
Todd was willing to under take the E85 tune project although it would be more work him.
The target is to to see how far we can push boost before we run out of injectors.
This should be fun project, stay tuned.
When we run out of injectors, I will be upgrading my injectors to 80lbs.
Todd emailed me a base tune(1.1 bar standard 1.3 bar Sport) that would work with my mods.
Installed tune and did a data-log, I think I smell burnt clutch
My timings look much better, please post your comments and feedback.
Todd is a pleasure to deal with, answers the phone himself and is willing to listen and comment.
Go Todd
File Type: pdf
Old Aug 9, 2010 | 08:59 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
MUCH better! Less boost & more power to boot
Old Aug 9, 2010 | 09:51 PM
TT Surgeon's Avatar
Much improved!
Old Aug 9, 2010 | 11:43 PM
TTdude's Avatar
Very nice! No worries there.
Old Aug 10, 2010 | 02:58 AM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
glad that you are happy with result and Todd is great guy to work with
Old Aug 10, 2010 | 07:17 PM
Todd emailed me a revised tune based on the logs I provided him.
Flashed Rev1 tune and data-logged.
Forgot to log timing on the 3rd gear pull.
Please post you observations and comments.
My max load is 230
File Type: pdf
Old Aug 10, 2010 | 11:37 PM
Abby997TT's Avatar
Your afr is going a little crazy above 6000 rpm. Todd recommonded to change the plugs. lower range is spot on.
Old Aug 11, 2010 | 08:53 AM
Yep, Todd thinks my plugs or a coil my be acting up.
Old Aug 11, 2010 | 09:16 AM
Abby997TT's Avatar
I am changing mine as well. Not sure if I should do it myself.
Old Aug 11, 2010 | 10:40 AM
bbywu's Avatar
Was the data logged with Durametric?
At higher RPMs, the AFR/Lambda readings go crazy (as previously reported by other Durametric users) due to sampling frequency.
Old Aug 11, 2010 | 10:53 AM
Used Durametric version 6(Beta), can I ignore the reading?
