What Battery Charger
Old Dec 9, 2010 | 04:31 PM
il nino's Avatar
il nino is infamous around these partsil nino is infamous around these parts
Is there any special way to keep the battery charged in the winter? Can I use any type of trickle charger? I have an extra Battery Tender for my Harley and was wondering if it will damage the battery to use it on my TT?
Old Dec 9, 2010 | 04:57 PM
jhbrennan's Avatar
H-D Battery Tender will work fine - I've used one for 3 years.
Old Dec 9, 2010 | 05:00 PM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
AGM and gel batteries require a different charging technique. Suggest you read this tutorial:
http://www.batterystuff.com/tutorial_battery.html
Old Dec 9, 2010 | 05:11 PM
The Bogg's Avatar
the ctek 3300 is suitable - I've got it on my 997tt right now. Same as the Porsche one without the Porsche label and much cheaper!
Old Dec 9, 2010 | 05:36 PM
jhbrennan's Avatar
I thought the OEM batts were wet cell. The H-D battery tender is just a re-branded Deltan.
Old Dec 9, 2010 | 05:41 PM
ruf_turbo's Avatar
The Ctek 3300 is good *IF* you use a typical wet cell lead/acid battery. But if you use an AGM type battery, such as Optima, you'll need a different charger. Spend a few more bux and get the Ctek 7002 because it supports wet cell and AGM type batteries.
Old Dec 9, 2010 | 05:53 PM
ruf_turbo's Avatar
He may have changed out the battery to Optima or Braille, etc.
That's why I suggested he read the tutorial.
Old Dec 10, 2010 | 03:49 AM
handdoc's Avatar
handdoc is infamous around these parts
i bought the OEM one that plugs into the cig lighter, works great and is easy
Old Dec 10, 2010 | 04:31 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Me2 i think is the best option
Old Dec 10, 2010 | 06:52 AM
The Bogg's Avatar
The OEM one is a rebadged CTEK 3300 (it's on another 6speed thread).
Old Dec 10, 2010 | 08:46 AM
bbywu's Avatar
Old Dec 10, 2010 | 09:03 AM
jhbrennan's Avatar
The newer Deltran Battery Tender Plus will do AGM and GEL. OP should check to see if his H-D charger is the newer version. If it's a recent buy probably yes since H-D batteries are AGM.
Old Dec 10, 2010 | 09:41 AM
krpt176's Avatar
krpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to beholdkrpt176 is a splendid one to behold
Originally Posted by bbywu
I have been using this little guy for the last year:
http://www.griotsgarage.com/product/...+manager+iv.do
I still drive the car 3-4 times a week regardless.
Any thoughts about this particular product?
Reading this thread scared me though. Wow scary to think that could happen.
Old Dec 10, 2010 | 03:23 PM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
http://www.glisteningperfectionstore...Charger/Detail
From one of the sponsors here. I have it connected to my wife's Turbo S now. I have the Ctec 3300 on my Turbo but like the Save-A-Battery unit on my wife's car better.
Old Jan 18, 2012 | 04:56 PM
msf's Avatar
msf
msf is infamous around these parts
I use battery tenders on my truck and two motorcycles. They seem to work fine. Keep your receipt because they have a ten year warranty. I use the throttle to charge my Turbo.
