My 997tt Sachs clutch review.
Vent, how about ease of engagment? No more difficult than stock with your particular setup (ok for daily driver?)? It seems like you are saying it's actually now better and easier?
Why did you mentioned these other things please: release bearing, pilot bearing, ring gear, bolts etc.?
I mean, are these things that I have to mention to installer to be replaced? TIA.
I'm one with the rattling noises. Drives me crazy sometimes. Maybe I'll get it checked one of these days. My setup is the ClutchMasters Stage 3/LWFW. It engages really high and the takeup is quite abrupt. Definitely took me a long time to get used to it. I'm pretty smooth with it now but it'll snap your neck if you aren't careful.
Oh man so glad some one else feels the same way about the notchy 2nd gear.
I fully depress the clutch to the floor and still have to bang it into 2nd sometimes.
if a lower engagement point does the trick I'm all for it.
The effort needed to push in the clutch is still just like stock, the engagement is lower, OEM which is high and odd. It is definitely fine for daily driving and that
is how I use mine(DD). This I don't know why but the shifting is much better maybe due to LWFW making the sync much faster.
The kit from Todd.K fixed the issue with notchy 2nd gear engagement and moved the take take up point closer to the floor like is should be unlike stock which is high.
The only time the higher engagement becomes an issue is when the light turns and I wasn't paying attention. I release the clutch too fast and stall it. Usually at a light or on a hill I will release the clutch 80% of the way up, right before it engages, so that I'm ready to input some gas more accurately. Was a bit tricky at first but I've got it now. I will likely look into the clutch stop though. Every time I let my friends drive the car they about kill us b/c they've stalled in an intersection or snapped our necks b/c they gave it too much gas in fear of stalling it. Maybe I should stop letting friends drive my baby. I just hate it when I tell them it has a hard clutch and they just roll their eyes like I'm a ****ty driver.
your crazy to valet your car!
I just bought the RSS clutch stop. I guess I was thinking it was something else to actually change the engagement point. This gizmo seems exactly like what I need. I'm a little unsure about getting rid of the clutch sensor but I'm the only one that drives my car and I leave it in neutral when parked.
. I think one really needs to weigh up the benefits of using the LWFW vs living with a rattle (that some of us may never really get used to) before pulling that trigger
Paul, very good report and good to hear that it feels like stock. Change from the stock feel is my biggest fear as I drive my car to work daily.
For those interested, the table below lists the Sachs plates; Paul uses the 764 and this is the one that is recommended by most. Don't use 752, even if yours is only stage 2 (exhaust and ECU); it's not strong enough. I know, I have to re-edit this table.
. Its definitely a necessary mod imo....i can honestly say that i feel the benefits just using the stock file so its going to be a blast once she's bed in nicely and ive re flashed the tune file back in.
It sounds a great set up....excepting for the rattle.
This is one mod im quite happy not to notice
This thread has become an excellent one because of the very good users' reviews -- very pertinent info.
Vent, did you get the whole set from Todd, or did he just gave you the part numbers and you had to buy them yourselves?
