Thinking of stepping up to a turbo,have a C2 and C4S
Old Feb 2, 2011 | 06:59 AM
Albert1028's Avatar
Albert1028 is infamous around these parts
Hey guys
looking for some input on the turbos,i have a 03 C4S coupe and a 99 C2 cab,any input would help,996 or 997?,problem areas?,what to expect costs
Thanks in advance
Albert
Old Feb 2, 2011 | 07:14 AM
OneFasTT997's Avatar
OneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud ofOneFasTT997 has much to be proud of
Originally Posted by Albert1028
Hey guys
Thanks in advance
Albert
997 for sure. No comparison. Having owned both I am absolutely blown away by how much more refined, smoother, nicer to drive, and more comfortable the 997 is. The 996 is not very nice to look at compared to a 997 as well and the interior of a 997 is finally the interior this car has deserved all along.
997 all the way in my opinion.
Old Feb 2, 2011 | 09:57 AM
CaptnCrash's Avatar
CaptnCrash is infamous around these parts
We have a 2011 997.2TT and it's very nice. Loads of go, with the suspension in normal mode very nice ride. Go to sport and you feel every imperfection and it's very tight. New DFI motor is an improvement, uses zero oil, very smooth and quiet. 6 speed MT is the same one P has used forever, very smooth and positive shifting [ 10,000% better than a cayman for example ] .
--CC
Old Feb 2, 2011 | 01:17 PM
tphss's Avatar
tphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of light
If you are able to afford a 997 Turbo go for it, it's much better.
Other than all the things mentioned above, I feel the main things are:
1) The new turbo technology with variable pitch, this is a HUGE improvement over the 996TT, the 997TT engine is just in a whole different level in terms of refinement, turbo lag and stock power. The maximum torque arrive MUCH earlier than the 996TT and also stays longer (996TT max torque 2700-4600rpm -- 997.1TT max torque 1950-5000rpm).
2) In low RPM's the 996TT engine is not very refined, and the turbo doesn't kick in nearly as smooth as in the 997TT, at least in stock form. This is most noticeable around town...
3) Interior is much better and the stereo is a HUGE improvement over the sound I have in my 996TT. Also in the 997TT navigation is standard and good.
4) It's nice to have the suspension setting button in the 997TT.
phil_m
Aug 26, 2015 03:08 AM
manishdutta
Aug 21, 2015 09:49 AM
Lucid Moment
Aug 20, 2015 02:22 PM
Phoenix604
Aug 19, 2015 10:39 PM
cab83_750
Aug 19, 2015 12:37 PM
