Protomotive GT3071's Drag + 60-130 results
Car made 735AWHP @1.5 bar on dynocom.
Next week i am going to dyno at higher boost on Dynojet.
Congratulation bro
. its time for torque convertor u will get off .2 sec at least and reduce a bit of weight and u will be in the 9 sec and if you need a little more power go with GTX 3071 . and run that meth injection which u disconnect and never used for better timing .. you still have many options to be in the 9 sec .
its a stock engine . and with those turbos / tip / stock engine /full weight .. its an achievement for that trap speed and time .
(mashallah)
(mashallah)
Congratulation bro
. its time for torque convertor u will get off .2 sec at least and reduce a bit of weight and u will be in the 9 sec and if you need a little more power go with GTX 3071 . and run that meth injection which u disconnect and never used for better timing .. you still have many options to be in the 9 sec .Thank you bro.
Soon i will start modding as you advised
0-60MPH 2.7 sec
100-200 4.7 sec
Be careful milou....most dynojet dynos can not run the Porsche AWD system without disconnecting the front driveshaft. Check with dynojet first before you do it to make sure that particular model can.
Congratulation bro
