What type of Brake Light Bulbs on 997.1TT?
Old Mar 12, 2011 | 10:14 AM
Jonnydeep83's Avatar
Jonnydeep83 is infamous around these parts
A really simple question, but I seem to have missplaced my owners manual manual. What is the correct bulb type etc. to replace a brake light on a 997.1TT. And is there anything "magical" about the bulbs porsche uses or will the ones from autozone work just the same .. thanks.
Old Mar 12, 2011 | 11:22 AM
jhbrennan's Avatar
You can find them and order from Suncoast too.
File Type: pdf
Old Mar 13, 2011 | 03:55 PM
gmoney's Avatar
my car oddly eats left brake lights every 7k or so, local autozone has them.
Old Mar 13, 2011 | 07:25 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Low beam headlamp
HID-D1S
High beam headlamp
H11
Parking light
2825
Front turn signal
7507
Rear turn signal
7507
Tail light
7225
Stop light
7225
High mount stop light
Assembly
Fog/Driving light
H8
License plate
6418
Back up light
7506
Front sidemarker
2825
Map light
3886X
Dome light
6411
Step/Courtesy light
2825
Trunk/Cargo area
6411
Under hood light
6411
Old Mar 21, 2011 | 04:46 PM
Soma415's Avatar
Soma415 is infamous around these partsSoma415 is infamous around these parts
Just finished replacing mine. Used Sylvania 7528 LL's bought at Kragen. They are 5W models rather than the 4W OEMs so i replaced both. Also, the two pegs on the base are in a 12/6 O'clock position rather than the 12/5:30 position from the OEMs, so you have to insert them a bit differently into the housing, but it can be done.
One other issue i had was that my left tail light didn't want to come out after removing the fastening screw. I thought perhaps i was pulling on it wrong, so i unscrewed the other first instead to check how it came out. Turns out the left light was just stubborn, so i gave it a few open fisted palms to loosen it up and it came out as planned.
Old Mar 21, 2011 | 04:57 PM
jhbrennan's Avatar
Why did you use the wrong bulb?
Old Mar 21, 2011 | 05:04 PM
Soma415's Avatar
Kragen recommended them as the replacement, they were P21, just 5W rather than 4W. I'd read of people using the 5Ws before. Didn't see the peg difference until i got back home and took apart the fixture. As they mounted up securely, provide brake lighting, i'm fine with them and don't have to spend another hour of my day running around to auto stores. It fixes my problem of no left brake light. I'll keep them until i go LED.
LiquidElephant
Aug 27, 2015 06:17 PM
GSR Autosport
Aug 26, 2015 05:20 PM
vchris
Cayenne 955/957
Aug 25, 2015 05:37 AM
metzkaro
Aug 24, 2015 02:59 PM
