Front Differential Fluid Leak Again
I have a friend who had a front differential leak on an 07 C4S when he bought it new . He told me that they replaced the entire front differential . His car had less than 300 miles on it if I recall correctly. He didn't keep the car long (traded for a Turbo) but said he never had the problem again after it was repaired .
In short .. it can be fixed.
Thanks for the comments. When I wrote "drip", I should have been more clear. After a week of sitting in my garage, there are 3 drops on the floor.
What I really want to know is if it is relatively simple to remove the car's plastic underbody. Any comments on that?
Anyone? Anyone? Bueller? Bueller?
Really? I thought you'd had yours replaced? Is it overfull?
I assume you checked the pentosin level is not higher than the max level marker on the plastic reservoir? If the level is fine then its back to the front diff.
Thats a pity although they are very common to fail. Your assumption is correct...the clutch slave and accumulator. Both need to be done at the same time and make sure whatever they fit is of 09 manufacture or later. The dates are on the boxes. Its the earlier pre 09 parts they had an issue with. When they did mine they just did the accumulator first and then had the car back a week later to do the slave....a bit inconvenient. Typical warranty dept looking to save time and money.
Felt the clutch pedal going gritty, popped the hood and the clutch reservoir was starting to overflow. Took it to the dealer and they replaced the slave only not the accumulator, asked and was told accumulator was fine. This was done under warranty.
What a great catch. The simplest thing -- the devil really is in the details. THAT shop earned some repeat business! It's great to have someone you can trust. GLAD that you got this fixed with the least amount of expense & hassle.
Exact same thing happened to my 2007 TT. I have had quite a few clutch issues with the car. Finally, at around 22k miles Porsche deceided to completely replace the entire clutch (which was only 20% worn) and they covered it at no cost to me. They told me they used newer updated parts and now it feels fine. The only issue is the smell eminating from the car if you ride the clutch even slightly. Thats not hard going up and down the hills of SF. The original clutch never smelled but that didn't do me any good with all the issues.
