Service question
Old Mar 24, 2011 | 11:52 PM
sc170's Avatar
sc170 has a spectacular aura aboutsc170 has a spectacular aura about
Service question
I have been looking at some Carfax reports in my search for a used 997tt. I have seen this in multiple reports:
"Engine removed for repair
Engine cleaned
Front crankshaft oil seal replaced"
Is this common? Should I run or should I consider this as one less issue to worry about?
Thanks in advance!
Old Mar 25, 2011 | 12:05 AM
Gotnem108's Avatar
Gotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to all
Run. Keep running.....And don't look back.
Old Mar 25, 2011 | 12:57 AM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Considering you almost have to remove the engine to change the spark plugs, I don't know if I would get too worked up over it.
Old Mar 25, 2011 | 07:04 AM
ImolaMS's Avatar
ImolaMS is infamous around these parts
agreed, open the rear hatch and see how much room you have.
I haven't seen this particular car but we oftentimes drop engines just to even fine boost leaks.
that line item wouldn't steer me away
Old Mar 25, 2011 | 09:15 AM
OKB's Avatar
OKB
OKB is infamous around these parts
if its still under warrantee, you dont have to worry
Old Mar 25, 2011 | 09:28 AM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Agreed. Depending on what was actually done, it may not be a big deal at all.
Old Mar 25, 2011 | 09:54 AM
sc170's Avatar
Thanks for the info.
Both the cars that I am looking at show this in their service records. I guess the bright side is that they are also CPO'd .
Old Mar 25, 2011 | 05:53 PM
GEO 450's Avatar
GEO 450 is infamous around these parts
I recently had a coolant leak and they had to drop the engine to get to it, like they said above very common in these cars.
Old Mar 25, 2011 | 06:02 PM
Jeff C's Avatar
Jeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of light
If car is CPO no worries.
Old Mar 26, 2011 | 02:15 PM
Serpentene's Avatar
Serpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant future
With the motor stuffed like a thanksgiving day turkey how else can you really work
on it with out a drop?
I seen a motor outside the car and it baffles me how it actually "fits"...
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
993 Guy
Sep 4, 2015 07:48 PM
gulf gt
Aug 27, 2015 10:27 AM
