PASM Suspension Upgrade
Old Apr 28, 2011 | 06:37 AM
xseal's Avatar
xseal is a name known to allxseal is a name known to allxseal is a name known to allxseal is a name known to allxseal is a name known to allxseal is a name known to all
Originally Posted by speed21
Yes I hear the TPC set up is a big step forward from the out of box pss10's.
So TPC dont use the 2 piece springs (helper springs) like the PSS10? Rating the stock set up as a 10 how would you rate the comfort level of the TPC compared to the stock ride comfort?
7-8. Definitely firmer, but controlled. If you think stock feels soft and not like a sports car, you'll like the change.
Old Apr 28, 2011 | 07:12 AM
GT-TT's Avatar
GT-TT is infamous around these partsGT-TT is infamous around these parts
I can confirm that B16 is a bit too soft for track use. As such a setup with stiffer springs would be better. Does anyone know what TPC is using?
Old Apr 28, 2011 | 07:26 AM
TT Surgeon's Avatar
If you want to do the coilover route, I would go with single adjustable motons from gmg.
Old Apr 28, 2011 | 07:44 AM
DaBrat's Avatar
DaBrat is infamous around these parts
Originally Posted by Casey@TPCRacing
Where are you located?
Hong Kong
Old Apr 28, 2011 | 09:58 AM
DaBrat's Avatar
Great! Thanks! Let me see which suspension I eventually decide on. If I choose TPC, I'll definitely contact you. Thanks!
Old Apr 28, 2011 | 02:28 PM
ArSe77aL's Avatar
ArSe77aL is infamous around these parts
Drop us an email to info@tpcracing.net We have installers in HK.
Casey
Do you have installers in Singapore or Malaysia?
Old Apr 30, 2011 | 01:57 PM
ArSe77aL's Avatar
http://tpcracing.com/info/dealers
Scroll down to the bottom.
Thanks Casey, am also wondering a few things:
Are the settings/comfort level of Damptronics in the Stage3plus suspension package the same as your TPCracing Damptronic coilovers alone?
And how would you rate the comfort levels of your TPCracing system compared to the Bilstein B16 Damptronics and then again compared to stock PASM? (Of course in Sport mode it doesn't really matter, am more concerned about the Normal setting)
Also are there any potential squeaks, rattles or sounds that might come about with any the above setups?
Old May 2, 2011 | 07:53 AM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Just had my Bilsteins installed and the difference is (definitely) night and day. On that note there was a 997 C4S owner who I was chatting with, who recently replaced his H&R sport springs + stock shocks with the bilsteins too. He’s comments were the same, upset with the stock and the H&R setup and loves the Bilstein Damptronic setup.
Originally Posted by GT-TT
I would say get something like a B16 + sways + toe links (a must in my experience)
My question is how much of a difference will fitting sways + toe links give.
Old May 2, 2011 | 08:02 AM
GT-TT's Avatar
answer is massive. The sways are the most effective way to limit roll (springs are distant second). Also the easiest way to fine tune balance of the car (over vs under steer).
RE toe links the difference is quite big as well. When driving on high speeds the stability you get is very apparent immediately. P should really have installed better suspension components in the back of those turbo cars but they preferred letting things move around and PASM, PTM etc correct things constantly..
Old May 2, 2011 | 08:14 AM
DaBrat's Avatar
Sorry to be a pain and revert back to a very fundamental question - what are your comments on getting a PASM vs. a mechanical non-PASM suspension (like the KW V3s)?
Am I sacrificing a better suspension for the PASM function? Or is the PASM function better than or equal to the mechanical non-PASM suspensions?
Once again, for me, it's a 100% road car.
Thanks!
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ECS Tuning - VW
Aug 20, 2015 02:01 PM
ECS Tuning - VW
Aug 19, 2015 02:36 PM
ECS Tuning - VW
Aug 19, 2015 01:23 PM
