brakes red vs yellow
Hello. As far as I understand on 997.1tt the red brakes are steel and yellow are ceramic? is the disk size is the same? or rd are 350 and yellow are 380mm?
If I have red calipers this means I have 350mm disks?
Then If I want to change from 350 to 380 what I need? can I use my red calipers or I need to buy yellow calipers and 380mm disks? would it fit my car? is it worth to do upgrade?
PCCB's are 380mm while the steel on the S models (red calipers) are 350mm.
Option is less since you get credit for the stock brake system - still a good value up front compared to changing later.
ECS Tuning - VW
Aug 20, 2015 03:07 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
