Bed Brakes Each Time I Switch Track/Street Pads
Old Aug 16, 2011 | 07:18 PM
Car-Narcissist's Avatar
Car-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond repute
Message Removed
Message Removed
Old Aug 16, 2011 | 07:40 PM
GT3 Chuck's Avatar
Administrator
I would bed the pads whenever I switched from street pads to race pads just to make sure all the street material was off the rotors...braking hard for a slow turn from high speed is not the time to find out you should have bedded the pads
Old Aug 16, 2011 | 07:44 PM
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
I have heard from race pad to street pad same rotor no, but from street pad to race pad same rotor yes and it might even be a good idea to do a double bedding in process to remove what the street pads leave behind.
I personally have not done this yet but will be doing it soon as I put 350mm Girodiscs on all 4 corners and new stock pads all around because I could not stand the pagids noise on the street. I will be doing an event early Oct so the time will come to slide the pagids back in and i will do a double bed process on these new rotors.
Old Aug 16, 2011 | 10:13 PM
djben's Avatar
djben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond repute
Originally Posted by Car-Narcissist
Do I have to re-bed the brake pads when I switch between track and street pads?
Not sure if this is the right section to post this question. Mods feel free to move it.
Yes, you need to do this.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
rnl
Aug 26, 2015 02:36 PM
awchristler
Bentley
Aug 24, 2015 03:53 PM
