What is this brake part?
Old Aug 17, 2011 | 03:36 PM
Car-Narcissist's Avatar
Car-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond repute
Message Removed
Message Removed
Old Aug 17, 2011 | 08:41 PM
bensonJ's Avatar
bensonJ is infamous around these parts
Both areas you're referring to are for vibration damping elements which equates to noise reduction. The aluminum posts are mounted on some sort of sheet metal disk that is stuck on w/some adhesive. The tabs/ears are for mounting counter weight style vib. dampers. You can run w/neither measure but can probably expect some knocking noise when going forward to reverse and vice versa.
Old Aug 17, 2011 | 10:03 PM
TT Surgeon's Avatar
Those are glued to the stock pads, I always removed them and mated them with my new pads. If you don't , it will be noisy for sure.
Re the holes in the pagids, those are for a pin that's used on a 996, some AM pads that are used in both 996/7 will have those holes.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
The Oss
Aug 24, 2015 08:19 PM
Vrseis
Aug 20, 2015 07:41 AM
