Buying a turbo. got a question
Old Sep 15, 2011 | 12:37 PM
richard181's Avatar
richard181 is infamous around these parts
Looking at an 07 Turbo with softronics 600+ tune, intake and exhaust work. Carfax showed failed emissuions than a passed emission a few days later. Do you have to remove tune for emission testing??
Bigger question.. should I be concerned about an 07 with a tune. car has 20K miles
Old Sep 15, 2011 | 12:49 PM
Hoen's Avatar
Hoen is infamous around these parts
Rear o2 sensors probably turned off in flash which could cause you to fail. Owner flashes back to stock or asks tuner to turn on rear o2s with modded flash and your golden for the test.
I would guess but not 100% sure that a flash and good exhaust should pass emissions test so long as you have the o2's all turned on. The post cat ones commonly get turned off as most exhausts will trigger a post cat CEL sooner or later.
Old Sep 16, 2011 | 03:46 AM
handdoc's Avatar
handdoc is infamous around these parts
i would guess that it had to be reflashed to pass emissions...i have had that issue w/ tuned vehicles as well
Old Sep 16, 2011 | 09:56 AM
Izwar's Avatar
Izwar is infamous around these parts
good miles
Old Sep 16, 2011 | 06:42 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
A good tune should pass emissions . I would steer clear of any flash with O2 sensors disabled, what else is turned off?? At 20k a tuned TT I'd ready for plugs- not cheap!
As a general rule I would try to find a stock car.
Old Sep 16, 2011 | 08:08 PM
Jeff C's Avatar
Jeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of light
Tune, O2 sensors on/off, failed emissions, hmmm???
I'd pass
COBB Tuning
Jan 1, 2025 09:02 AM
COBB Tuning
Nov 9, 2015 08:02 PM
L.A.P.
Oct 19, 2015 10:01 PM
MrNurse
Sep 10, 2015 09:44 AM
