Best brake setup
Old Sep 27, 2011 | 05:10 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Best brake setup
Im looking into changing my pads and disc's very soon and wondered what all you guys are using or what is the most common/best setup for road/track use, mainly road?
Old Sep 27, 2011 | 08:27 AM
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
On my 996tt I just put the Girodisc slotted 2pc rotors on all 4 corners in a 350 size. I will test them out in a few weeks at the first DE I will attend since the install. I am running oem pads for now bc I got tired of all the noisy brake pads.
Prior to the event I will be putting Pagid Yellow up front and Black on rear in the stock 996tt caliper sizes. Prior the the rotor replacement I ran the above race pads on stock rotors and found the combo to work very well so I am thinking it will be same if not a bit better due to the slightly larger rotor.
Since yours is a road car mostly, I would go with a pad that does not squeal like a pig so much. Not sure which one that one would be but perhaps others can input?
My buddy has a 997.1 with the Brembo Big Brake Kit and it stops well and looks cool but he is limited to wheels he can run due to size of set up. I have had the oem ceramics on an 05 Turbo S cab and now a 12 Turbo S coupe and WOW! is all I can say.
I don't know if it is because they are new 1600ish miles or what but they have a ton of stopping pwr. I know they are expensive and have a reputation for being high maint esp if you will do alot of tracking. Having had them before and being used stopping a 3400-3500lb car with stock brakes where the car feels like what it weighs in comparison to with the pccb's where the same weight car feels like it's a 2k lb car.
Good Luck!
Old Sep 28, 2011 | 07:42 AM
E55AMG's Avatar
E55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud of
Do your rotors need to be replaced?
Old Sep 28, 2011 | 07:49 AM
GTRNICK's Avatar
They need to be changed soon.
Old Sep 28, 2011 | 09:13 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
Sent you a PM
Old Sep 28, 2011 | 11:19 AM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
Brembo GT 380 BBK
danyoP4S
Sep 30, 2021 05:06 AM
ModBargains
997 Vendor Classifieds
Oct 13, 2015 03:53 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
