E-brake Replacement
Old Feb 16, 2012 | 06:27 PM
911t-gts's Avatar
911t-gts is infamous around these parts
E-brake Replacement
Does the rear center console have to be removed to replace the e-brake handle? I know there's a cut out under the handle but not sure if that gives enough access to remove the entire assembly. Thanks.
Old Feb 16, 2012 | 08:21 PM
bbywu's Avatar
Just the handle piece or the entire e-brake unit?
To remove the e-brake unit, you must remove the center console. To remove the center console, you must remove the lower portion under PCM as well.
Old Feb 17, 2012 | 03:09 PM
911t-gts's Avatar
Actually, I'd like to replace just the handle piece. Didn't know that was an option. How do you seperate the handle from the assembly? Also, can you buy just the handle? All I've seen is the entire assembly for sale...
Thanks.
Old Feb 20, 2012 | 07:08 PM
911t-gts's Avatar
Still looking for some help with this...has anybody replaced just the e-brake handle without pulling the entire assembly? If so, how? Thanks.
Old Feb 20, 2012 | 09:23 PM
bbywu's Avatar
It depends on the type of handle - some are easier to remove than others.
Old Feb 21, 2012 | 01:08 PM
911t-gts's Avatar
http://www.youtube.com/watch?v=30ahm...layer_embedded
Interesting...similar to a golf club grip.
I'm trying to swap this full aluminum handle:
With this leather and aluminum handle:
Can these be r&r'd the same way?
Old Feb 21, 2012 | 01:52 PM
bbywu's Avatar
Probably not.
Jun 10, 2017 07:45 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 24, 2015 09:29 AM
Jeff1smith
Aug 19, 2015 09:41 PM
