What is TUV? - HRE Wheels
Old Mar 6, 2012 | 12:13 AM
HRE_Wheels's Avatar
HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !
What is TUV?
Over the years HRE has received numerous questions regarding TUV certification. What is it? Why is it important? What is required? Other companies are starting to claim they have TUV certification and we have received numerous questions as to whether these claims are true or false. HRE can’t determine whether others are properly going through the legitimate process of getting TUV approval or just falsely claiming TUV approval to improve their image. What we can do is clarify what is required of TUV and what you should be looking for from a company that claims to have TUV approval.
http://www.flickr.com/photos/hrewheels/6958105815/
1) WHAT IS TUV? - In the case of wheels, TUV is a European auditing and certification body that ensures wheels manufactured for sale in Germany, Switzerland and Austria meet international (ECE Regulations), EC (European Community) directives, and German Motor Traffic Agency (KBA) road traffic legislation.
2) HOW DOES TUV WORK? - There are 3 major aspects to receiving TUV certification.
a) Manufacturer Certification (Certification of the wheel manufacturer’s quality management system) - If you aren’t an actual manufacturer you can’t be a TUV certified manufacturer. If you’re not a real manufacturer and your supplier isn’t a TUV certified manufacturer you cannot have your wheels TUV approved. This requires that the actual manufacturing facility (in HRE’s case this is our production facility at our headquarters in Vista, CA) passes an audit every 3 years by TUV authorities from Europe. The facility must ensure the manufacture of its wheels meet the standards set by the authorities above in point 1. This is very similar to an ISO 9001 audit and designed to ensure consistent quality of manufacture. TUV wants to ensure that wheels sent to TUV for te sting are not “ringers” and that all wheels manufactured at the approved facility meet the same standards. HRE’s quality management system was originally certified in 2008 by Germany and recertified in 2011 by Austria (which is applicable for Germany).
b) WHEEL TESTING CERTIFICATES (Certification of wheels as conforming to geometric standards and having passed structural fatigue and impact requirements for specific vehicle and load rating requirements) - Once a manufacturer’s facility is certified they are then able to send wheels to Europe to pass TUV geometric tolerance analysis and testing for fatigue and impact. This is not a generic style-based test, but vehicle-based with each style being tested with the proper widths and offsets and load rating for the appropriate vehicle targets. This is a very time consuming and costly endeavor for any manufacturer to TUV certify their entire wheel offering, particularly a brand like HRE that makes custom fitments and offers dozens of styles for any particular vehicle. Given this fact, HRE does not certify every style and fitment, however we do have multiple styles in several fitments tested, approved and certified for sale in Germany, Switzerland and Austria. Regardless of certification, ALL HRE wheels are designed to pass TUV structural specifications (with varying load ratings depending on vehicle targets) and are sent for certification when the demand for them in Europe meets a minimum threshold.
c) VEHICLE OWNER CERTIFICATION (Certificates ensuring wheels installed on an owner’s vehicle are TUV certified for that vehicle) - This is a certificate that the owner of the vehicle receives from TUV authorities showing his wheels are TUV certified so he can legally register his vehicle and pass annual inspections in Germany. The wheel manufacturer does not supply this document.
3) IS TUV FOR WHEELS ONLY? - TUV does not only cover wheels. It covers everything from toys to wheels to appliances so companies may hold TUV certificates that do not in any way allow them to legally sell wheels in Germany, Switzerland or Austria. By the same token HRE is only able to sell wheels (not toys) and only those wheels tested in Europe having passed the appropriate tests. None of this is possible without FIRST receiving the manufacturer certification. More importantly, simply by having a wheel pass a TUV test does NOT mean you are a TUV certified manufacturer. You must have a manufacturing facility to certify and that facility must pass the audit.
4) WHY DOESN'T HRE PUBLISH TUV CERTIFICATIONS? - We’ve been asked for a long time to publish TUV certificates. For many reasons HRE does not publish internal specifications and documents, but we will deviate from that decision to help clarify the confusion and show you our manufacturer certificates from 2008 and 2011 and we will show you an example of a wheel testing certificate; in this case the latest wheels sent to TUV for testing, a P43 in 20x9.5 ET42, PCD 5/114.3. The tests required 3 wheels to be tested for cornering fatigue, radial fatigue and impact at 750kg, a much higher level than the original design load rating. All passed. These tests certify the P43 style in that specific width, offset and PCD for that specific load rating.
http://www.flickr.com/photos/hrewheels/6811989550/
http://www.flickr.com/photos/hrewheels/6811989436/
http://www.flickr.com/photos/hrewheels/6958099537/
5) HOW DO I KNOW IF A COMPANY IS REALLY TUV APPROVED? - TUV obviously wants to ensure others aren’t making false claims about TUV approval. For this reason they have a simple website system to check a manufacturer’s TUV Registration ID number. HRE’s current TUV ID number is 20102112006509. This number can be confirmed as genuine by following the link below to the TUV website and entering the registration number or simply typing in HRE. Ask a manufacturer for their registration ID number and website link. They should be proud to give it to you.
HRE TUV ID check: CLICK HERE
http://www.tuev.at/start/browse/Webs...rter%20Partner
Search for ID 20102112006509
http://www.flickr.com/photos/hrewheels/6958082695/
TUV RHEINLAND CERTIFICATE CHECK, http://tuvdotcom.com/?locale=en
http://www.flickr.com/photos/hrewheels/6812002656/
If there are any further questions, please don’t hesitate to ask.
HRE Factory tour
Here are some great video tours of the HRE facility and how HRE makes wheel
http://www.egarage.com/videos/hre-wheels/
Old Mar 6, 2012 | 03:46 AM
zooyorker's Avatar
zooyorker has a brilliant futurezooyorker has a brilliant futurezooyorker has a brilliant futurezooyorker has a brilliant futurezooyorker has a brilliant futurezooyorker has a brilliant futurezooyorker has a brilliant futurezooyorker has a brilliant futurezooyorker has a brilliant futurezooyorker has a brilliant futurezooyorker has a brilliant future
Fantastic news for both you and us swiss guys! Congratulations! Will all wheels, no matter how aggressive the offset is be TüV certified?
Best,
Yannick
Old Mar 6, 2012 | 05:31 AM
FadeToBlack's Avatar
FadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of light
Congratulations. Great thing you've got there.
What you don't know is that by having a TUV certificate for a wheel made for a specific car the warranty should not be voided by the manufacturer/dealer in Europe, according to European law, if there is a TUV certificate. This applies to European Union, but I am sure other European countries recognize TUV as well.
Old Mar 6, 2012 | 07:32 AM
Tech1_Mike's Avatar
Tech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond repute
Just to clarify, the TUV "certification" is not a TUV "approval". It is a certification that the company receiving the credential has a satisfactory quality management system. This is very similar to the ISO 9000 certificate.
TUV does not "Approve" companies per se.
Wheels, on the other hand, do receive TUV "approval".
The first step is a "Gutachten". This certifies that the wheel in question has the strength to survive the TUV tests at a given stated load.
Next is the "Teile Gutachten". This certificate approves a specific wheel for use on a specific vehicle. This approval number is machined into the wheel and, in Germany and Austria, the approval certificate must be carried in the car at all times. If you have aftermarket wheels and no certificate, your car will be impounded.
HRE is one of the best wheel manufacturers in the world with a serious commitment to quality and safety. Kudos.
Old Mar 6, 2012 | 11:06 AM
Swiss made's Avatar
Swiss made is infamous around these parts
Exclamation No TUV in Switzerland
TUV certification will not help you to get your wheels street legal in Switzerland. The Swiss authority will not accept TUV certificates because Switzerland is not part of the European union. It sure confirms that TUV certified manufactures fullfill very high quality standards.
I was still able to get my HRE's street legal. You will need a certificate of the wheel manufacturer that confirms that you can run the wheels on your car. In my case HRE Europe helped me out and confirmed that I can run the c93 in 19x8.5 and 19x12 on my GT3.
For the Swiss guys on the forums:
I'll be very happy to help you out if you have any questions.
Additional information can be found here: (2.1 --> TUV certificate is not valid)
http://www.stva.zh.ch/internet/siche...Felgen1202.pdf
Aug 21, 2015 09:56 AM
ModBargains
Aug 20, 2015 12:28 PM
