Difficulty starting
Old Mar 11, 2012 | 10:35 AM
Trauma's Avatar
Trauma is infamous around these parts
Difficulty starting
Hey gang- interesting issue with my 08 997tt. Every now and then, the car will not turn over when I turn the key. The engine begins to start, then decides not to. I have to turn the key off, then restart again. It always starts on the second try. It does this intermittently. Strangely, the check engine light was on for a day, and before I could take it to the shop, it went off.
I am going to take it to the shop when I get a day off, but I'm wondering if anyone has any idea what might be causing it. I had a new battery installed three months ago, and I doubt this is the issue...
Old Mar 11, 2012 | 10:54 AM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Perhaps your starter motor or a solenoid is starting to fail. Best get it checked out while you can still drive it to the shop. Best,
Old Mar 11, 2012 | 11:20 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Could be a bad ignition switch. Have you ever noticed whether it has anything to do with how you insert the key or maybe a different key you use?
Old Mar 11, 2012 | 01:51 PM
Slider's Avatar
It could be a charging problem. There must be a reason you had to replace the battery. I've been putting my 996 TT on a charger once a week since my last battery died after just 2 years (even after I replaced the alternator).
Old Mar 14, 2012 | 08:50 PM
Trauma's Avatar
Interesting. So I dropped it off at the shop today for 30 minutes. They replaced the clutch sensor, which they told me commonly causes this problem. Pretty painless really...
Old Apr 30, 2012 | 03:40 PM
gmoney's Avatar
had mine in for the same thing, clutch sensor replaced. Car still did it. I just replaced the battery myself 10 minutes ago with an Interstate and car starts like it should, night and day difference vs. the stock crap battery which was just over 4 years old. I guess Im lucky I got that much out of it.
Old Apr 30, 2012 | 04:47 PM
Slider's Avatar
You should still put it on a battery charger once a week or your new battery will die prematurely also.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
