Tyre diameter question
Old Apr 21, 2012 | 08:20 AM
Peskarik's Avatar
Peskarik is infamous around these partsPeskarik is infamous around these parts
Question Tyre diameter question
I've heard that having tyres with big deviation in diameter from the stock (+/- 2.5%) is detrimental to the drive train and also the speed is shown wrong.
997 Turbo comes with 235/35/19 tyres in the front.
On 9x20 rims that are on the car the 235/30/20 tyres look too narrow, the rim sticks out. The difference in diameter is only 0.31% though.
Would it still be OK to put 245/30/20 tyres on the front, even though the diameter difference is now 1.24% ?
What are the negative effects of these tyres on the car?
This is a very important and serious question for me!
Thanks in advance!
P.S. Speedart BTR uses 245/30/20 tyres up front:
http://www.sportauto.de/bilder/speedart-btr-ii-580-evo-im-tuning-test-der-porsche-911-als-bi-turbo-racer-3891385.html?fotoshow_item=5#fotoshow_item=4
Last edited by GT3 Chuck; Apr 21, 2012 at 09:01 AM. Reason: active link to another forum
Old Apr 21, 2012 | 09:51 AM
997tttiplux's Avatar
997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute
Peskarik
What tires do you have on the rear? Which deviation do you have there?
The eventual trouble lies in the front/rear ratio deviation. Not in the front itself, not in the rear itself.
Old Apr 21, 2012 | 10:24 AM
Peskarik's Avatar
Originally Posted by 997tttiplux
Peskarik
Rears sit on 12x20s and are 325/25/20.
Deviation to stock 305/30/19 is 0.62%.
Basically, if I put 245/30/20 on the front that will be exactly like on SpeedArt BTR II 580 EVO, but I am not sure if one has to adjust something somewhere (transmission, speedometer) in order to be able to fit these tyres.
Old Apr 21, 2012 | 10:32 AM
I won't make the calculation there but if you have the same trends front and rear (for instance, let's say + 1% front and rear), you won't have any trouble.
as a reminder, calculation example for a 325/25x20" tire.
Diameter = 325x0.25x2+25.4x20
Old Apr 21, 2012 | 10:45 AM
Peskarik's Avatar
from tyre calculator
245/30/20 = 656mm
235/35/19 = 648mm
+8mm = 1.23%
325/25/20 = 670mm
305/30/19 = 666mm
+4mm = 0.62%
Old Apr 21, 2012 | 11:00 AM
oem 19" ratio front / rear = 638.875 / 656.45 = 0.9732
20" ratio front / rear = 655 / 670.5 = 0.9768
It looks quite similar to me.
Zero911
Aug 24, 2015 06:51 PM
Mar48
Aug 24, 2015 01:13 PM
