Fabspeed Quad Tips - Install Questions
Old Aug 7, 2012 | 07:23 AM
fpd's Avatar
fpd
fpd is infamous around these partsfpd is infamous around these parts
Had dealer install (i know, i have no mechanical skills!!) when my new to me 09 turbo cab was in for a minor item service. The black chrome tips look great with the Meteor Grey exterior. i do have a couple of questions...the left tips are perfectly aligned. When i look at the right side, the far right tip is perhaps a hair higher. I'm probably splitting hairs here, but since these are one piece items i have the following questions for guys who have done this install:
1) is it possible to loosen the bolt and adjust the tips? i probably need at most, an 1/8 of an inch clockwise rotation to make the right side perfect. Is there any play clockwise or counter clockwise when you put these on before tightening?
2) what specific tool is required to lossen or tighten the bolt? Can this be done without removing the rear bumper?
Thanks is advance and again please excuse my complete ingnorance. Having a lot of fun with the car as it arrived from Blue Grass Porsche the day i left for an overseas trip so i have only just been starting to drive it.
Old Aug 7, 2012 | 08:49 AM
quick's Avatar
quick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant future
Congrats on the car and yes the tips are adjustable and it is very simple to take them off/adjust them without having to remove the bumper.
Jack up the car and after securing it on the stand or better yet, drive it over 4-6" thick wooden piece, crawl underneath the car and you will see a single bolt that's holding the tips to the exhaust pipe.
If memory serves me right, the bolt either takes a 13 or a 14 mm socket so not much to worry about. Loosen,adjust and tighten the bolt and you are done.
Old Aug 7, 2012 | 07:17 PM
M3 S3-R's Avatar
M3 S3-R is a jewel in the roughM3 S3-R is a jewel in the roughM3 S3-R is a jewel in the rough
Thumbs down Fabspeed exhaust tips.
I purchased a pair. Not only did they not align. The way the tip is designed black carbon drips down on the lower bumper giving a nice black carbon streak on my GT silver paint. I tried moving the tips further out and still get the black dripping over the paint. With these tips on they also started to melt the black exhaust rings. I have removed the tips and went back to stock. What a waste of money. I'm running a cargraphic exhaust, which I was told would work with these tips.
Old Aug 8, 2012 | 05:55 AM
Berndindallas's Avatar
Berndindallas is infamous around these parts
I put the black crome tips on my TT (EP1 exhaust) a few month ago and never encountered any of these problems. There's some moisture accumulating on the inside after starting the car but that disappears when the exhaust system is warm. And the plastic cover around the tips looks good as new. Are you sure you've put the tips on the right way? Maybe too far in or misaligned and some blow-by exhaust is melting the plastic?
And the alignment is easily changed too. I crawled under the rear and adjusted it at least a half dozen times, but that's just me being a&al about it...
Old Aug 8, 2012 | 07:28 AM
fpd's Avatar
fpd
what tool did you use to do your adjustments?
Old Aug 8, 2012 | 08:52 AM
All you need is a 13 or 14mm socket wrench (memory is not what is used to be) and a bit of patience. After I loosened the nut securing the tips I wiggled it into place (there's a bit of play to move them around) and secured it with some small softwood wedges I had lying around in the garage to keep it from moving when I tighten the nut. Just don't forget to remove whatever you used to secure the tips in place before starting the car.
Oh, and what quick said, drive the rear wheels on some wooden blocks, just make sure the car is in gear and the parking brake on before crawling underneath the bumper...safety first.... Works like a charm and will give you enough room under the car to work the tips.
joseph_number1
Jul 19, 2018 05:45 PM
Jun 10, 2017 07:45 PM
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
