Lifting Up Those Front End Spirits - KW HLS Kit
Want to lower your car but just can't bare the scraping of your front end? Time to shell out some duckets for the new KW Suspensions HLS kit. The HLS system goes along with the KW coilovers or some factory suspension setups to allow you to raise and lower the front end from inside the car. This gives you the best of both worlds. Great looking stance and incredible ride.
The KW HLS (hydraulic lift system) provides additional road clearance for lowered vehicles. When expanded, a range of 30mm to 45mm of lift is produced, thereby helping sport cars avoid road clearance difficulties like speed bumps, road constructions etc.
Version HLS 2: Enables only the front axles to be lifted and lowered.
Features:
- For vehicles with with little road clearance
- Vehicle specific applications
- Activation of change in height by a small keychain transmitter avoiding the need to run additional wires through the vehicle
- Height changes can be done while the vehicle is moving, up to speeds of 50 mph
- Automatically lowering of the vehicle
- With TUV certificate
- Rubber bellows protect hydraulic cylinder, thereby providing long term durability
The hydraulic cylinder unit is installed between the spring perch and spring. The pump unit is installed inside or near the spare wheel well. A programmable control unit processing the CAN Bus signal for speed control is also included in the kit.
If your shopping for coilovers or interested in this new HLS kit, check out our full KW Suspension Store here - http://www.vividracing.com/kwcoilovers. Enjoy this little video we put together of the HLS 2 system being installed and under demonstration on our Porsche 997.2 Turbo S.
Features:
2lflat4
11-18-2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
