Sponsored by: Bears Transport
997TT MK.1 PCM 3 conversion DONE :)
Rating: Thread Rating: 2 votes, 5.00 average.
  #631
Old 05-31-2018, 01:12 AM
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
No. Europe map is 4 dvd set available as spare part.
  #632
Old 05-31-2018, 01:07 PM
walter12's Avatar
walter12 is an unknown quantity at this point
ok.
After driving a few kilometers navigation works - so i will see if i gonna need an update or not
  #633
Old 06-04-2018, 09:50 AM
walter12's Avatar
@Stroker
With a vehicle handover the ac unit stops flashing.
  #634
Old 06-21-2018, 02:27 AM
walter12's Avatar
Is there a possibility to display the data such as last trip, mpg, mileage etc. on the pcm3?
These are not available, i can only display temperature, time, height and rest reach?
  #635
Old 06-22-2018, 02:19 PM
Serg124's Avatar
Only first tab is working, second and third no...
  #636
Old 06-24-2018, 04:31 AM
Obelix's Avatar
Obelix is an unknown quantity at this point
I have already retrofitted the pcm 3 into my 997 with Bose.
So fare the system work but the Bose has a very low bass volume!
In addition the sound characteristics is very low.
I think that the reason therefore is that the used Bose amplifier comes not from a 997 coupe (don't know the origin)
Is there a possibility to adapt the amplifier?
Don't found some clear coding in PIWIS
  #637
Old 06-25-2018, 03:05 PM
Serg124's Avatar
Maybe you want something different from bose that can't be done? Try to listen to it in other car.
For those who don't get much from bose there is two options
First is to replace speakers to mix of focal burmester etc, there's a separate topic here
Another option is to replace amp with audison bit dmi and almost any amp and speakers you like.
  #638
Old 09-21-2018, 01:48 PM
walter12's Avatar
After 3 month my pcm3 doesnt work.
Yesterday i drove the car, but the pcm didnt start.
After 45min i could turn it on and i could hear music, but i had to information in the dash.
After turning off the ignition the pcm remained on - and it displays the message that without engine running i could only use it a few minutes (But the engine was running)
I turned it off and after getting back to the car 30min later i tried to turn it on again, but it didnt worked.
After 40min whilst driving i could turn it on, but after 2min it restarted.
Then i could hear music until i put it off. It still doesnt turn off when putting ignition off.
Any idea what i can do?
The pcm3 is not available in piwis.
In the dash i have some error codes:
  #639
Old 09-22-2018, 06:03 AM
walter12's Avatar
The error codes are from the gateway ans not the dash
  #640
Old 09-24-2018, 06:30 AM
Serg124's Avatar
....mmm I didn't see any good options. I think you need another pcm
  #641
Old 10-04-2018, 05:57 AM
Obelix's Avatar
Hello,
Once again I'd like to ask About the Bose coding…
According Porsche PET I have to check the coding of the amplifer.
At PIWIS I found some coding posibilities.
So what are the correct values for a 997 Coupe ?
  #642
Old 02-04-2019, 07:58 PM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Originally Posted by Stroker
Hi guys, the switch units have different connectors.
The bigger one ist the newer one.
- what have you done to solve this?
Thanks for helping
David
Hey guys, I'm undergoing this same project, only I'm using an aftermarket head unit, so not fideling with the most complex part.
I'm only replacing the air control unit and the lower switch assembly.
It's unclear what work needs to take place to get the 997.1 wiring harness connected to the new switch (that sits below the air con unit).
Also did you guys need to change the internal "cage" that holds all the components?
Essentially what happened to me is my mechanic pulled it all apart and mentioned that the 997.1 internal cage has different mounting points for the 997.2 air con unit and switch assembly. He also mentioned that the pins don't match for the switch assembly - which is essentially what you guys show.
1) So my question is, can you provide more detail on how you connect the 997.1 wiring to the 997.2 switch assembly, given they have different pins.
Are you saying that pim 1 goes to pin 1, 2 goes to 2, etc. this will change given different locations of the numbers?
If this is correct, will one need to solder? Does any one have any photos of this operation?
2) Did you replace the metal interior "cage" to mount the new assembly?
  #643
Old 03-07-2019, 07:29 PM
Bump on this.
I just need to understand the PIN connections.
Is this the way it needs to be connected?
...as in diagram 1 or diagram 2?
  #644
Old 03-07-2019, 09:26 PM
Fig 1 shows the 997.2 connector:
Fig 2 shows the 997.1 connector
Fig 2 green background shows where the pins are in the connector.
Fig 3 shows the position of the retrofitted 9971 plug into the 997.2 connector
Fig 3 yellow background shows the new location of the pins using the old (shorter) plug.
Is that correct???
  #645
Old 03-07-2019, 10:00 PM
Serg124's Avatar
Why don't you use wiring diagrams? This is important.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: 997TT MK.1 PCM 3 conversion DONE :)
