Spark Plug attempt Save $1300?
Old Apr 16, 2013 | 12:43 AM
LeoLambo's Avatar
Lamborghini Fanatic
LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !
Originally Posted by elite1
great information! I jsut bought Denson IK20 and they have a 1.10MM gap on them. I am not sure on the stock air blow that the spark may encounter but, i would assume it to be more with my new exhaust.
Your gap projected illustrates 0.8mm which in my opion is much less.
THanks for sharing the information! I hope to understand this better.
I can't really go into details because i don't talk about things that i don't know much about it BUT you should contact Scott ( SOFTRONIC ) he is full of knowledge and willing to share it.
Old Apr 16, 2013 | 12:50 AM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Because of your post I, will value you opinion from this point forward. I honor you honesty. I will wait and contact Scott as he may have the awnser to this. Thanks for all your help. I couldnt contact him without you.
Old Apr 16, 2013 | 12:54 AM
LeoLambo's Avatar
Lamborghini Fanatic
Thank you! i'm sure he will tell you what's the best way for you to go!
Gluck my friend
Old Apr 16, 2013 | 12:56 AM
elite1's Avatar
Gluck my friend
Thanks! When do you sleep?
Old Apr 16, 2013 | 12:59 AM
LeoLambo's Avatar
Lamborghini Fanatic
LOL now!! night, night nite!!
Old Apr 16, 2013 | 07:57 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
1.1mm is wider than the stock gap. If anything you want to be at stock gap or smaller on a modded car
Old Apr 18, 2013 | 02:17 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
$1300 seems like an awful lot for labor on plugs. Should be a 4-5 hour job at $130/hr +/-. I bet you could get it done for a ton less by a qualified indy and not sweat it yourself if so desired.
Old Apr 18, 2013 | 06:04 PM
skinny electra's Avatar
skinny electra is a splendid one to beholdskinny electra is a splendid one to beholdskinny electra is a splendid one to beholdskinny electra is a splendid one to beholdskinny electra is a splendid one to beholdskinny electra is a splendid one to beholdskinny electra is a splendid one to behold
Thanks Skinny, I see most take the oil lines off or completely remove the Turbos. What do you do? If you take the lines off do I have to bleed them?
sorry for delay responce..i didnt take lines off..just take your time and you will b fine..Honestly not that hard just time consuming..Im no mechanic and was able to do it..i left turbos on and all..
sean
Old Apr 21, 2013 | 05:17 PM
elite1's Avatar
I completed the change. I will agree, “Torture.” Especially if you don’t take any lines off or remove the turbos. I ended up removing a line on the passenger side to complete it. I would like to see the tool that one would use to remove the torx type screw on the most front plug without removing the oil line.
Overall, all but the most front two plugs are very easy. The plugs I removed had a 0.3mm gap on them. I decided to go with 0.35mm for the new set as my next upgrade will be the softronics software.<O</O
Old Apr 21, 2013 | 07:02 PM
LeoLambo's Avatar
Lamborghini Fanatic
Congratulations!!! no many people (i'm the first one) can fix their own car.... what exhaust do you have?
Old Apr 22, 2013 | 06:24 PM
elite1's Avatar
I got the Europipe stage 2. Exhaust is amazing. Turbo spooling above 2,300RPM. Not too loud at all. Will post an update after next weekends driving on it.
Old Apr 22, 2013 | 06:36 PM
LeoLambo's Avatar
Lamborghini Fanatic
Nice! Enjoy your car!
Old Apr 23, 2013 | 11:46 PM
Steve_TT's Avatar
Steve_TT has a spectacular aura aboutSteve_TT has a spectacular aura about
Elite, you went with 0.035" gap? Not 0.025"? Still waiting for Softronic to confirm the recommended gap.
I am a decent DIY and am considering doing the plugs, but the plug stories are scaring me. Any good tips from your install? I hate unplugging fluid lines. Did you have to flush or something afterwards?
EP2 is awesome. A cold start from across the street apparently rattles the windows on my house.
Old Apr 24, 2013 | 09:18 PM
elite1's Avatar
Hi Steve TT. I managed to unplug the turbo tube without losing much oil at all. Just before the line reached its disconnection I slide a rubber damn through the connection eliminating fluid lose. I may have been too concerned about having to bleed lines. I did the same for the reinstallation process. Maybe someone else could shed some light on the correct process to this procedure.
Out of the box the plug gap was 1.10mm for the Denso IK20. The plugs that were removed were set to 0.30mm. I decided to set them at 0.35mm. I think most on the forum set them to 0.25mm. I believe that the temperature rating of the plug and chamber environment state will also demand the gap to be set differently. Sorry I can’t be much help on that exact number that I was originally looking for.<O</O
Old Apr 25, 2013 | 01:16 AM
Steve_TT's Avatar
Scott at ST said 0.028 to 0.030 for the gap on my EP2/Softronic tune combo. I understand 0.032 stock and 0.025 for high boost, so I guess the recommendation makes sense for my 93 octane tune (I was told only 1.4 bar peak boost). Hope your gap doesn't cause problems.
Thx for the tips. I might consider doing the plugs myself now...
