997tts Europipe Users Question?
Old May 9, 2013 | 07:27 PM
Jeff C's Avatar
Jeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of light
If you get the Europipe you won't listen to the radio/Ipod any more. Love mine. Everyone in your garage will be jealous.
Old May 9, 2013 | 07:57 PM
Tims997TurboS's Avatar
Tims997TurboS is a name known to allTims997TurboS is a name known to allTims997TurboS is a name known to allTims997TurboS is a name known to allTims997TurboS is a name known to allTims997TurboS is a name known to all
Originally Posted by stef@europipe
Two mass airflow sensors (MAF) are used on a 997.1 Turbo to detect the intake airflow and on the older 996 Turbo it is just one mass airflow sensor. The new 997.2 Turbo doesn't have MAF sensors but it uses a manifold absolute pressure sensor (MAP) inside the intake system to decect the intake airflow. The data of the MAP is used by the ECU to calculate the air mass flow.
The ECU does not detect exhaust backpressure though and there is no backpressure sensor anywhere the exhaust system. That's a dead giveaway.
As with the 997.1 Turbo, there is a temperature sensor inside the housing of each turbocharger. The maximum allowed temperature is 980°C, otherwise the ECU will decrease the turbo boost and enrich the air fuel ratio to protect the engine.
With our 997.2 Turbo sport exhaust you will feel the increased hp and torque at low rpm and midrange as well as the sharper throttle response but there is no gain at the top. The same effect happens with better intercoolers, near the top rpm range the ECU takes over and the gains are gone. An ECU flash will transform the benefits of a sport exhaust and better intercoolers into more power but with a stock ECU the maximum output is limited to 500 or 530 hp.
Hi Stef,
Thanks for responding to me email relative to this issue. I appreciate you posting your response on 6Speed, and am very impressed with your prompt and professional feedback. I look forward to doing business with you!
Tim
Old May 10, 2013 | 06:15 AM
stef@europipe's Avatar
stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !
My pleasure Tim
Old May 10, 2013 | 10:17 AM
TT Surgeon's Avatar
There may not be a true back pressure sensor in the exhaust system, but the ecu does monitor pressure on the intake side large expansion manifold and compares this with other parameters and is capable of pulling timing. when you flash the car, this can be adjusted and the car will really run good with the ep.This is something unique to the 997.2.
It's not just me saying it, ck out a thread over on rennteam. Where there's smoke, there's fire.
Old May 10, 2013 | 03:02 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Just a clarification...that 997,1TT uses two air flow meters and a map sensor (bolted just before TB) while 997,2 has deleted air flow meters...
Old May 11, 2013 | 10:50 AM
That is the MAP sensor I've mentioned earlier.
That car has a 9ff exhaust with valves so that at full throttle you're running with straight open pipes. Our EP sport exhaust has nothing in common with that system.
Old May 11, 2013 | 02:48 PM
TT Surgeon's Avatar
Other than both reduce backpressure.
I think the op should buy whatever he wants and report back.
Old May 11, 2013 | 03:00 PM
My pleasure Tim
Thanks Stef...I just placed my order.
Tim
Old May 12, 2013 | 09:07 AM
Tim,
Thank you for your order and thank you for your confidence.
Cheers, Stef
Old May 12, 2013 | 10:57 AM
Johnny DB's Avatar
Skandalis,
Any drone with your EP2?
nlakind
Nov 6, 2015 10:15 AM
STAGGERED M3
Sep 11, 2015 12:00 AM
gulf gt
Aug 27, 2015 10:27 AM
