08 997 tt code p4690 and p4691
Old Aug 30, 2013 | 08:10 AM
canada0323's Avatar
canada0323 is infamous around these parts
Need help all, I was told I had these two codes I Believe it may be related to recall w902. Called porsche directly and the advised this was done back in 2009. What can I do?
Old Aug 30, 2013 | 11:37 AM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
There are literally hundreds of Porsche error codes: http://www.permoveo.ltd.uk/tabid/123...e/Default.aspx
Unfortunately, p4690 and p4691 do not appear in the database although that doesn't mean they don't exist. Have the codes been cleared and do they return? What type of shop did the scan and what type of scanner was used - PIWIS, Durametric, something else?
My only advice at this stage would be to go to a P-dealer or a very good indy shop that has a PIWIS scanner (specific to Porsche) and have them get to the bottom of your issue(s). Good luck!
Old Aug 30, 2013 | 01:44 PM
svoshop's Avatar
svoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond repute
You need to get the Porsche codes. The American version you have listed does not show up. Use a durametric and get the manufacture codes.
There is a difference.
Mike
Old Aug 30, 2013 | 09:37 PM
997TTMeister's Avatar
997TTMeister is infamous around these parts
As that recall was only some grease added to the actuator rods, and you had it done in 2009, I wonder if this is not something that needs to be done every few years. I always thought this was a weak fix, given the part has been superseded.
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
oddjob142
Aug 24, 2015 05:49 PM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
