Head gaskets
Old Sep 22, 2013 | 01:29 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Head gaskets
Guys who makes high performance head gaskets for the 997 turbo?
Also who runs the stock gaskets with high horsepower without any problems?
Old Sep 22, 2013 | 03:59 PM
MegioN's Avatar
MegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to all
I am using stock 997tt headgasket, works perfect, boost levels 2+ bar
Engine is okay 2 years with a lot of racing, every week.
Carrillo rods, arp headstuds and stock gasket
Old Sep 22, 2013 | 04:20 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Evolution installed Hellfire gaskets, Carrillo rods and strengthened head bolts when they built my motor 18 months ago. The gaskets will likely be the least expensive part you put into your motor...... http://www.evoms.com/marketplace/ViewProduct.asp?Now=9%2F22%2F2013+3%3A18%3A57+PM&P roductID={397D3913-CF73-4FF2-BE67-7A45EEDD4CCA}&OrgID={CA5E16BC-D877-4137-8237-7EB9084DD3D8}&ParentID={DB632267-FE09-40D4-866E-E6F70332D6E0}&Curr={DB632267-FE09-40D4-866E-E6F70332D6E0}
Old Sep 22, 2013 | 11:51 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Also using stock head gasket with Protomotive custom o-ring heads and sleeves to match.
Old Sep 23, 2013 | 12:16 AM
GTRNICK's Avatar
Thanks a lot guys. What is the thickness of the stock gasket?
The reason being is I have found these below
http://www.shopengineparts.com/produ...bo&type=engine
Which seem to be the same description as the EVOMS gaskets but $250 cheaper!
Old Sep 23, 2013 | 12:36 AM
TTdude's Avatar
Stock is 0.027". Note: Cometic 996tt gasket has three holes for coolant passage whereas stock does not. If you go Cometic get GT3 gasket (single cut out for coolant) but I don't think you will be able to get stock thickness.
Old Sep 23, 2013 | 01:21 AM
GTRNICK's Avatar
Why do you reccomend the single cut out apart from it being same as stock? Are there downsides to having 3 holes?
Also cometic do a 0.027" for 996tt engine but you mean not for the gt3?
Old Sep 23, 2013 | 08:37 AM
TTdude's Avatar
I view it as being potentially restrictive. With high hp build, I wanted to ensure greatest coolant flow possible.
Old Sep 24, 2013 | 07:47 AM
GTRNICK's Avatar
Thanks guys for your advice!
Glasgo
Nov 30, 2015 02:37 PM
007 Vantage
Oct 8, 2015 08:35 PM
sportscentury
Sep 30, 2015 10:48 PM
ECS Tuning - VW
Sep 29, 2015 01:49 PM
marcallan
Sep 26, 2015 09:07 PM
