Help with upgrading turbos?
Old Feb 16, 2014 | 12:43 AM
MA1's Avatar
MA1
MA1 is infamous around these parts
Hello, I have an 07 turbo with 3" exhaust, filter, clutch and tune. I am looking into upgrading to 3076r's. What is needed to do this upgrade? Is it possible to use stock headers? I'm not looking to go over board or max the turbos, I just want more power on pump gas. If someone can write me a list of what is necessary I would appreciate it, thanks!
Old Feb 17, 2014 | 08:09 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
How much power do you want to the wheels on pump gas? If max power is not your main concern, maybe there's a VTG option out there that will meet your needs...
Old Feb 17, 2014 | 11:15 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
If you go for the Tial Alpha turbos you can use the stock headers although you might need some higher flowing headers but you can always try it first and change at a later date if the funds are low.
You will also need bigger injectors possibly 850cc and an external boost controller plus some intercoolers and a Y-pipe with blow off or recirc valves.
Mackchacha
Jul 9, 2019 11:03 AM
vr6tee
Aug 29, 2015 03:52 AM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
Vrseis
Aug 20, 2015 07:41 AM
