Rear interior side panel removal
Old Apr 3, 2014 | 05:47 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Hi Guys, scoured the net and can't find and nice DIY to remove the rear panel on my 997.1. If anyone can point me to a source it would be appreciated.
Old Apr 4, 2014 | 09:14 AM
cjcam930's Avatar
cjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond repute
Just curious, are you looking to remove the rear seat belts, or doing this for some other reason? I don't have the info either but it did not look super intuitive and I did not want to break any trim pieces, so when I did the rear seat delete last weekend I just rolled-up the seatbelts behind the panel. I replaced the cover with the opening with the one without the opening (from Suncoast).
Old Apr 4, 2014 | 10:58 AM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Check for a seat belt diy. Should be one on rennlist. I've done it. You need to remove the b pillar and the upper seat belt attachment. Can't avoid it. Hardest part is the seat belt clip, tricky to get off.
Old Apr 4, 2014 | 03:43 PM
Jako's Avatar
Thanks Guys, i was under the assumption their was a drain tube behind there. I am experiencing wet back seat bowls and was going to do the wheel inner fender clean trap this weekend and thought that if it wasn't too hard. i would try it inside too?
Or maybe i miss read something and there is no drain on the inside part and just behind the rear wheel inner linning?
Old Apr 4, 2014 | 06:24 PM
ryem3's Avatar
I don't recall any drain access after removing the panel.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
Jeff1smith
Aug 19, 2015 09:41 PM
