GSR Autosport - Mezger GT1 - Coolant Pipe Fix or Roll the Dice?
Old Aug 5, 2014 | 09:18 AM
GSR Autosport's Avatar
GSR Autosport is infamous around these parts
Turbo good to go!
After replacing the 4 - O.E. plastic pipes with stainless steel Sharkwerks units in addition to pining the coolant hoses, gmoney's Turbo was good to go!
Old Aug 8, 2014 | 07:43 PM
The Bogg's Avatar
If the engine is already out how many hours is it for the pinning job not including reinstalling the engine?
Old Aug 8, 2014 | 09:10 PM
Jonnydeep83's Avatar
Jonnydeep83 is infamous around these parts
Originally Posted by Steve K ny
i'de roll the dice.
100+k miles from both my metzger turbos and this was never an issue.
I had one of the coolant hoses leak which was fixed under warranty. Then about a year later (out of warranty) I was driving with my wife in the car, who was pregnant at the time, when the coolant dumped. Thankfully, I wasn't going fast (I think it started dumping when I went over a railroad crossing a few miles from my home). My advice is to fix it, it's more than worth it. It's worth while to replace all of the coolant hosing (and seals) around the engine while you are at it. I also upgraded to the Sharkwerks GT2 coolant pipes. http://www.sharkwerks.com/products.php?pid=394 No problems since.
Most of the cost is in taking the engine out. Might as well go all out if you are doing that.
Old Aug 9, 2014 | 09:32 AM
The Bogg's Avatar
I was going to do it but was quoted 17 hours and that was with the engine already out.
Old Aug 9, 2014 | 12:47 PM
lexart's Avatar
lexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond repute
I think it took me less then 17 hours to pin my pipes and that's with the engine IN the car. I followed this excellent thread on Renn http://forums.rennlist.com/rennforum...n-the-car.html
Our cars are slightly different and require 7 pipes to be pinned http://rennlist.com/forums/997-turbo...any-parts.html but with a bit of elbow grease and perseverance one can do this themselves for less then $20 in parts.
Old Aug 9, 2014 | 01:40 PM
swole305's Avatar
swole305 has a spectacular aura aboutswole305 has a spectacular aura aboutswole305 has a spectacular aura about
17 hours!! - my total job including changing the clutch was around 20 hours including the engine pull and put back. Also has few other things done but 17 hours is a rip off with engine already out.
Old Aug 10, 2014 | 08:59 AM
The Bogg's Avatar
Thanks for the input guys. Any idea what a reasonable quote would be in my case?
Old Aug 10, 2014 | 09:21 AM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
If the engine is out and on the ground, there is no reason to take longer than 2-3 hours to pin them. I did it in the car with no prior Pcar experience in less than a day!
Old Aug 11, 2014 | 01:31 PM
The Bogg's Avatar
Is it any different for the 997tt? I note that u have a 996tt.
Old Aug 11, 2014 | 01:37 PM
The Bogg's Avatar
Is there a way to check for leaks from the pinning without first reinstalling the engine? I recall being told that one of the reasons for the cost was in case engine had to be dropped again to fix leak from the pinning.
Old Aug 11, 2014 | 02:00 PM
jhbrennan's Avatar
Both have the GT1/Mezger block - should be the same.
Old Aug 11, 2014 | 04:10 PM
Vantaredoc's Avatar
I used the instructions from the Renntech post which was for a 997! Mine had one or two additional fittings.
Old Aug 14, 2014 | 11:16 AM
The Bogg's Avatar
I just got clarification from my indy - they aren't completely dropping the engine to install the larger turbo inlet pipes and that's why it costs so many additional hours if I wanted the pipes pinned. Guess I'll wait till there's another reason to drop the engine or if I experience problems (fingers crossed )
Old Aug 14, 2014 | 12:35 PM
nuclearfishin's Avatar
nuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the rough
I just had this repair done on my car with 34k miles. Here are some pics of the repair along with a few pics of the IPD Plenum install and gt3 TB.
Old Aug 14, 2014 | 01:49 PM
The Bogg's Avatar
Neat, thanks for the pics. Did you have coolant dripping? I see some pink foamy fluid from the pics.
