McKenzie Cylinder heads
Old Apr 20, 2015 | 12:29 PM
  #31
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
videos of the sexy machine please....this thread is the equivalent of those romance novels...lol.
Old Apr 21, 2015 | 06:26 AM
  #32
cjv's Avatar
cjv
Moderator
I can remember old Alex introducing McKenzie's work years ago. The results were impressive back then.
The above numbers are very interesting. We took a slightly different approach when we did our heads. We first tested heads and then manifolds individually. We found that we were able to get good numbers individually, however when we tested the heads with the manifold we found a wide variation between individual runners. Flowing as we ported (cleaned up) produced a balanced head/manifold combination. I say "cleaned up" because we used stock Cup heads with stock Cup diameter valves with larger stems.The intakes and exhaust were not really ported. Slight grinding was used to match individual port flow and then the manifold runners were also matched.
Here was our final flow results utilizing head/manifold/throttle body and flow testing the manifold runners.
https://www.6speedonline.com/forums/...ml#post4293361
007 Vantage
Oct 8, 2015 08:35 PM
Sep 28, 2015 02:19 PM
Bobbyfali
Sep 27, 2015 01:55 PM
marcallan
Sep 26, 2015 09:07 PM
