Strange sound from my GT2 turbos and oil leak
Old Mar 20, 2015 | 07:43 AM
bennakhi's Avatar
bennakhi is infamous around these parts
Hi,
While I was cruising last night in my 997.1 GT2 I heard weird noise like grinding coming out from the left side turbo. When I arrived home I saw an oil spot on the Y-Pipe as shown in the picture below. The weird thing is boost still 1.4 bar which perfect and there is nothing wrong with car at all. Anyone might know what is the problem?
Car mods:
Protomotive tune
Forge DV's
BMC Filter
OEM exhaust decated
Old Mar 20, 2015 | 08:01 AM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
You should pull the outlet hose off the turbo (the one going to the intercooler). See if oil comes out or if it's wet. If it is pull the air inlet to the turbo to see if it's coming down the inlet into the turbo. If not you may have a seal starting to go in the turbo. You could have someone drive behind you to look for any smoke from the exhaust.
Old Mar 20, 2015 | 08:26 AM
Tareq's Avatar
Tareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant future
Maybe try speak to Yousaf Al Wattar (ysfg35 on here) and together both of you can diagnose the issue?
Goodluck, and keep us posted, inshallah its nothing Major
Old Mar 20, 2015 | 11:39 AM
G911's Avatar
G911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of light
i think you will need change turbos soon, cause they start drop oil. its normal situation.
and about noise maybe its from turbo, and turbo die soon. but maybe its from headers, headers leak also very offen situation
Old Mar 20, 2015 | 12:04 PM
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
Do you see any smoke coming out while driving / stopped ?
Old Mar 20, 2015 | 02:16 PM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Turbo seal leaking, its actually the lesser evil, if the oil is coming from the engine that would probably be tons of $.
If/When it goes its a perfect opportunity to get some nice 65-68mm ones
Old Mar 20, 2015 | 03:16 PM
bennakhi's Avatar
No smoke at all
SharkyShark20
Sep 19, 2015 09:54 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
Lucid Moment
Aug 20, 2015 02:22 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
