Building oil pressure before startup
Old Jun 12, 2015 | 01:32 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Originally Posted by The Bogg
It is fuse D7 - ignition coil/ injector valve. I assume that means no fuel will be sprayed. There was a thread a couple of years ago recommending this method - in a discussion about winterizing the car. The idea was to circulate some oil before the car actually started.
Good info...Thanks
DC
Old Jun 12, 2015 | 05:52 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Originally Posted by xbox_fan
I have a 2007, it dont do this even after 4weeks, maybe you have an actual issue to look into?
That might be the case - I am keeping a close eye out for it as this has happened the last 2 times I left the car sit for 4-5 weeks.
Old Jun 13, 2015 | 07:41 PM
95RogueM3's Avatar
95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of
Originally Posted by TimeTomorrow
New to Porsche, but most cars retain fuel pressure in the line, so a fuel pump cut is a bad idea. You would need an injector cut to achieve what you are trying to do and that's probably going to throw a code
Same thing with Porsches. Even if you cut the fuel pump, the rail would still hold enough fuel to fire the engine (and then die shortly thereafter).
Whenever I changed the oil on my 996TT, I would pull the fuel pump fuse, start the car and let it run out of fuel on its own. Then change the oil, crank the motor for awhile to build oil pressure, then replace the fuse and drive as normal.
proTUNING Freaks
Sep 15, 2015 07:28 AM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
m_motorsport
Sep 2, 2015 12:53 PM
