Is keeping the rear wing down possible?
Old Jul 11, 2015 | 02:58 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Hi,
I had the Techart type 1 rear wing and went back to the oem because I disliked the TA one when it is in "up" position.
I was thinking about bolting it again if I could find a way to keep it in "down" position.
Does someone know how?
Thanks, P.
Old Jul 11, 2015 | 03:19 PM
MBA's Avatar
MBA
MBA is infamous around these parts
I had the dealer program my wing to stay down when the hydraulics went out, so yes it's possible
Old Jul 11, 2015 | 05:59 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Yes...If you have a Durametric Pro you can do it also. There is likely another option to unplug the connector, and find how to loop it so the DME does not give an error when you reach the deploy speed. This is done when people switch to a fixed wing, so I know it is possible.
If I can find the wiring needed I will post it here. Meanwhile search for that on google. Fixed wing vendors have a plug that does this I believe.
Good luck!
DC
Old Jul 11, 2015 | 06:02 PM
therock88's Avatar
Old Jul 11, 2015 | 06:06 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Yes P I turned mine off with the PIWIS. OR you could pull a fuse out.
Old Jul 11, 2015 | 06:07 PM
therock88's Avatar
Found this too in my documents folder...should help guide you.
DC
File Type: pdf
Old Jul 12, 2015 | 03:42 PM
K24F's Avatar
Ok much thanks buddies,
I used my Durametric pro and it seems to be ok: the rear wing stays in down position even >75mph and the lonely way to move it stays the dash button.
So I rebolt my TechArt wing but in despite my friends love it I'm not convinced with the aesthetic, even always down...
werkzrs
Apr 23, 2020 12:03 PM
Jul 29, 2019 11:13 AM
gulf gt
Aug 27, 2015 10:27 AM
undefnd
16
Aug 26, 2015 07:59 PM
