GT2RS Inspired 997 Turbo build...
Old Dec 8, 2016 | 05:52 AM
  #316
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
That will have to be compensated with a visit to Germany.
Rheinring (Anneau du Rhin) and beers are on me if you make it down this way.
Old Dec 12, 2016 | 09:57 PM
  #317
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Gents,
I'm undergoing this transformation right now.
I do have a question however. I'm not going the center radiator route, so would you know if I need this part, I'm thinking not...
#13 Frame Air Exhaust
99757532580
Old Dec 13, 2016 | 07:22 PM
  #318
Never mind - just found out it is necessary
Old Dec 17, 2016 | 09:35 AM
  #319
isysman's Avatar
isysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond repute
Sorry I never got a page update so only just saw this. That part you outlined is part of the centre vent, and it actually comes with the centre vent. (or part number 4 in your diagram)
If you don't change the centre radiator how will the ducting fit? I've heard of people doing the GT2 front bumper without doing the Rad but I don't know how everything would fit so I'm curious.
Old Dec 19, 2016 | 02:14 PM
  #320
mthaynes's Avatar
mthaynes is a jewel in the roughmthaynes is a jewel in the roughmthaynes is a jewel in the rough
be careful with fitting the gt2 rs carbon center vent. they are prone to cracking. let it sit where it wants. avoid stressing the carbon in any way. hope this helps.
Old Dec 29, 2016 | 08:30 PM
  #321
marzz's Avatar
marzz is a glorious beacon of lightmarzz is a glorious beacon of lightmarzz is a glorious beacon of lightmarzz is a glorious beacon of lightmarzz is a glorious beacon of lightmarzz is a glorious beacon of light
heaps of work, well done, looks great
Old Dec 30, 2016 | 03:13 AM
  #322
isysman's Avatar
Thanks.
Old Jan 15, 2017 | 11:07 AM
  #323
Hey Isyman, I noticed on another british forum you mentioned that you had to replace the hot side ducting, frame, attachment strip, and gaskets when you upgraded the rear bumper.
Would you have the part numbers for those?
Old Jan 15, 2017 | 12:53 PM
  #324
isysman's Avatar
Hi, if you're talking about the intercoolers ducting, that's correct. I don't have the part numbers, it was all ordered by Tech9 who were doing the job. I already had the GAt2RS intercoolers fitted so all the ducting, the intercooler frames even etc. If you call Porsche they will have that info if you just ask for GT2RS parts.
Old Jan 15, 2017 | 01:43 PM
  #325
Cool, thanks. Need to give that some thought as I'm already running larger champion intercoolers.
Old Jan 15, 2017 | 09:36 PM
  #326
isysman's Avatar
Maybe try to get the dimensions of both and compare.
Old Jan 31, 2017 | 05:07 PM
  #327
isysman's Avatar
Made a short update video for my car. Let me know what you think.
https://youtu.be/NyCSF-X-kdE
Old Jan 31, 2017 | 05:17 PM
  #328
isysman's Avatar
Double post
Old Jan 31, 2017 | 06:33 PM
  #329
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Well, now I know how my airbox got a hole burned through the back side. Thanks for posting. I'm still somewhat confused though, is it the AC compressor that didn't get mounted correctly or the box itself?
If anyone else has a damaged air box, I have a brand new 997.2 TT complete assembly available for purchase. I bought it thinking it would work in my 997.1, unfortunately the dot one and dot two boxes are not compatible.
Old Jan 31, 2017 | 06:38 PM
  #330
isysman's Avatar
Initially they said it might be worn engine mounts causing the engine to move and hit the AC pump. Excuse to buy new RSS engine mounts! They quickly dismissed that however but I still replaced the mounts just in case.
