Lower Cost Titanium Lug Bolts
#37
-Craig
#39
If you purchased a set of our titanium lug bolts and could leave a review on our site, that would be awesome.
Heres the link to leave a review.
http://www.world-motorsports.com/por...-bolt-set.html
#41
No, not yet. We are working on that but it is going to be quite a while before thats available. If everything goes smooth;y the earliest we will see black ti is 6 months.
#43
Hopefully someone that purchased them for black wheels can chime in on that. They should look amazing on any color wheel compared to the stock ones because the appearance of the titanium bolts is so much nicer than the stock bolts.
Thanks-
Thanks-
#44
I weighed them using a Tiff digital refrigerant charging scale.
I bought 10 stock length ones,.. and 10 in extended length for a set of Elephant Racing 10mm spacers I'll be running in the rear.
So I weighed 10 of the stock length ones and 10 of the factory ones. Then doubled the numbers to simulate a sets of 20.
Results?
A set of 20 stock ones weighs 4.15 lbs
and 20 Ti ones weigh 2.87 lbs.
So you save 1.28 lbs total buying a set of 20 lugs,... or about 5 oz per wheel.
They are beautiful however. No regrets here.
For those of you searching for a great set of spacers to go with your lug bolts,... here's a couple pics of the Elephant Racing spacers.
They aren't generic spacers like most,.. but rather they're CNC'd for Porsche.
So even the 7mm ones are hub-centric.
http://www.elephantracing.com/suspen...el-spacers.htm
They come in 7mm, 10mm, and 21mm.
They also have 1mm, 2mm and 5mm shims,.. which can be used either in front or behind the spacers,.. so that you can achieve pretty much any spacing your heart desires.
These are 10 mm ones going on the rear.
Results?
#45
Results?
Results?
