Boost on stock vtgs
Old Mar 21, 2016 | 09:38 PM
  #31
EvoSpecJBray's Avatar
EvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond repute
Originally Posted by A418t81
The factory VTGs work quite well at 22 psi as well, and gain about the standard amount of power per lb of boost as would be expected going from 20 to 22. My IATs are very much in check with standard 997.2 intercoolers.
Here is a run through all of second, third, and 4th gear on pump gas. Notice the boost pressure and RPM. My IATs at the start of the pull were 76 degrees. Final temp is 104 for the sake of rounding. Ambient temp was in the 60s.
This map is good for 60-130 times of 6.7 seconds.
Nice! yes looks very good. I suspect you have decent air where your at. Elements of course has to be thrown in. Testing in the great 110 degree desert heat always put a frown on my face. That car must rip at that power on stock turbos!!
Old Mar 22, 2016 | 03:50 AM
  #32
IMI A's Avatar
IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !
I have never been able to run more than peak boost of 18-19 psi efficiently on mile + runs with GT2 hybrid VTGS with 66mm compressor wheels. Still manage to run 6.5 secs to 100mph, just under 17 secs to half mile at 160mph and 26-27 secs to 186mph. Not bad for a stock engine turbo on VTGS. In gear its quick 50-70mph in 1 sec flat.
I can run 21-22 psi on short quarter mile and half mile runs and go even quicker but anything longer at these higher boost levels I get ignition being pulled.
I wonder if running E85 + meth helps as we just run pump gas mixed with a bit of MS109.
Old Mar 22, 2016 | 06:56 AM
  #33
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Originally Posted by elite1
Usage environment means everything.
I could use my stock VTGS at 22psi on occasion with no issue. Head to the track and see how easily they fail.
I'm with John on this debate.
Of course usage duty cycle dictates the tune used. I've never said otherwise. I disagree that 22 psi with the correct intercooling, octane, and tune would cause the turbos to fail on the track, but I do agree that the tune my car has now is from the appropriate tune you would take out to do some serious track time with. The car is tuned for the street and acceleration runs, not sustained peak output for many minutes. Those are opposite ends of the spectrum. There are many variables, not just boost pressure, that I would change for a tracked tune.
Old Mar 22, 2016 | 07:32 PM
  #34
changster's Avatar
changster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond repute
Add a gallon or two of E98 or E85 to your pump gas tune and I'll bet the knock goes away.
Boost Logic
991 Turbo Vendor Classifieds
Mar 3, 2016 11:01 AM
onefastman1
Feb 28, 2016 01:00 AM
CPIGUY
Feb 25, 2016 05:21 PM
Drifter911
Feb 24, 2016 03:55 PM
Feb 23, 2016 09:51 AM
