PCCB caught fire, pics, now what?
Old May 18, 2016 | 10:29 PM
TT Chris's Avatar
TT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud of
Originally Posted by changster
Trofeo R's are like slicks... might as well run cheaper Hoosiers!
But yeah I get ya... will start practicing with everything off and work up to speed.
I use to drive to the track so I can't drive there on Hoosiers. Plus if it rains it will be a waste of the day.
Old May 18, 2016 | 10:47 PM
changster's Avatar
changster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond reputechangster has a reputation beyond repute
Do you find Trofeo R's much faster than a Cup 2 tire? Also do you find the 245/325 to be much better than 235/305? Just curious.
Old May 19, 2016 | 12:05 AM
TT Chris's Avatar
I've never tried Cup2 but if I had to guess I would bet trofeo is still stickier. The low treadwear rating tells me that. 325 just looks more mean. Plus has more grip. Since I'm running over -3 degrees of camber I want more tire on the pavement.
Old May 19, 2016 | 03:24 AM
changster's Avatar
Sweet. I'll be trying the 245/325 on R888's next week. I've trying to minimize variables so I can feel the difference on every change.
Old Jul 4, 2016 | 09:32 PM
changster's Avatar
Originally Posted by IMI A
Stay away from SICOM for refurb. Looks like they're going to the wall.
http://www.pistonheads.com/gassing/t...=1502023&i=200
Business is tough nowadays. Guess they are going through rough times.
Old Jul 5, 2016 | 07:21 AM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Sounds like they were slacking when business was more than good (F1 work etc)
Old Jul 5, 2016 | 10:58 PM
TrackAddict997's Avatar
TrackAddict997 is a jewel in the roughTrackAddict997 is a jewel in the roughTrackAddict997 is a jewel in the rough
Ive tracked with ceramics many times and you should always make sure to clear/clean the little holes in the rotors at the end of the day bc they fill up with debris like yours in the picture.. If left for more then a day they will harden/clog and the rotor will start heating to a higher temperature then it should, as those holes help with cooling. Definitely helps with longevity on ceramics for those of us tracking them.
Old Jul 12, 2016 | 03:21 PM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
As others have mentioned, just switch to steel rotors - it will pay off BIG in the long run.
The previous owner of the car left the PSM on ALL the time and it discolored the rear calipers horribly. He had almost no camber on the front and too much negative camber in the rear because he was sooooo scared of the car coming around on him.
I am at -2.7 up front and -1.7 in the rear and the car feels amazing.
Old Jul 12, 2016 | 07:14 PM
changster's Avatar
Ahhh, thanks for the tip.
Old Jul 12, 2016 | 07:15 PM
changster's Avatar
I actually have a set of steel's ready with some aggressive Pagid pads. I'm going to try them soon.
Old Jul 14, 2016 | 12:41 PM
TimeTomorrow's Avatar
TimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to behold
Originally Posted by turboslut
You paid extra to have ceramic brakes (unless you just wanted yellow calipers). Fix the brakes and do it right....that refurb procedure looks promising and makes sense.
This doesn't make any sense. 997 PCCB's are not suitable for track duty. It's insane to replace them if you know the replacement isn't up to the use you intend.
gtron
Mar 3, 2020 02:00 PM
spooltime
Apr 22, 2016 09:58 PM
santon997
Apr 11, 2016 07:32 AM
Triple7
Apr 4, 2016 12:08 AM
Polar993
Mar 24, 2016 01:04 PM
