997.1 Turbo Shift light Install
Old Jun 1, 2016 | 02:50 PM
kpm.austin's Avatar
kpm.austin is infamous around these parts
I have looked an haven't been able to find any definitive answer. On the 997.1 turbo, can the light be tapped into the OBD II port under the foot well, or does it need to be tapped in near the ecu.
Old Jun 2, 2016 | 07:08 AM
Originally Posted by kpm.austin
I have looked an haven't been able to find any definitive answer. On the 997.1 turbo, can the light be tapped into the OBD II port under the foot well, or does it need to be tapped in near the ecu. Thanks
you should be able to get rpm from either location.
#TeamAIM
Old Jun 2, 2016 | 07:53 AM
kpm.austin's Avatar
Thanks, now if I can find an easy way to access the OBD II port I'll be set!
Old Jun 4, 2016 | 07:47 PM
TripleNet's Avatar
TripleNet has a spectacular aura aboutTripleNet has a spectacular aura about
How about a "shift beep" ... like the beep when you set a speed limit ?
keithta
May 21, 2016 05:06 PM
dgreen78
Apr 30, 2016 07:18 AM
away
Apr 7, 2016 05:51 PM
jjurroz
Mar 28, 2016 11:52 AM
