TheRock's 997.1 TT Water Pump Install DIY Guide
Old Sep 3, 2016 | 07:21 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
OK,
At the request of some 6Speeders and others I put together another document / DIY to help those looking to add/replace their Water Pump. This illustrates the process on a 997 TT, but could apply similarly to many other models.
As always, I hope you find it helpful. If you have a better way to do it...Knock yourself out. I created this DIY and put in the time in the spirit of helping my fellow enthusiasts.
Good luck to you all. It is a pretty straightforward process, and I hope I documented, illustrated, and outlined it in a way that is easy to follow and logical!
Certainly, if you see opportunities to help others, or tips please post here for others.
I host these on my personal Google Drive so if it gets a lot of traffic, it may flake out....so just try again until it works.
Enjoy, and let me know if it helps....
DC
Old Sep 3, 2016 | 08:09 AM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Great write up. I did this job last year along with the PITA thermostat
Old Sep 3, 2016 | 08:33 AM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
Another great DIY. Thanks
Old Sep 3, 2016 | 10:59 AM
therock88's Avatar
You are quite welcome...
DC
Old Sep 3, 2016 | 06:25 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Rock as usual killing it with awesome DIYs! Thanks man!
Old Sep 4, 2016 | 05:13 AM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
Thank you for posting this I find it very interesting. I do not have a lift , all the tools mentioned nor your mechanical skill but I very much enjoyed learning how this come apart and goes back together.
I hope to be able to do more on this car some day.
Thanks for taking the time to help the community here , I know if not easy to do these diys let along illustrate them so professionally.
Old Sep 4, 2016 | 06:58 AM
saabin's Avatar
saabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond repute
Another solid DIY from DC.. Thanks bud.. This might get added to my winter project..
Old Sep 4, 2016 | 07:53 AM
therock88's Avatar
You guys are welcome. Glad to help.
DC
Old Sep 5, 2016 | 01:25 PM
The Bogg's Avatar
Awesome diy guide as always Rock! As soon as I read "wobble extensions" I knew this wasn't a job for me, lol. Just kidding about that part but I still don't think I'd do this myself. I didn't realize the engine needed to be dropped for this otherwise I would have had it changed when I recently had my plugs done. Oh well, live and learn with this car. I think I will change out the idler pulleys and belt at the same time when I get this done in a year or 2. Are there any other pulleys to be changed at the same time? Thanks again for posting this guide to make us less technical guys feel good about our decision to pay somebody else to do it hee hee.
Old Sep 5, 2016 | 02:11 PM
therock88's Avatar
Haha...You are welcome, and no problem. It is really not as hard as it may look. Like everything...just follow the steps carefully, and TAKE YOUR TIME. But if you are not comfortable, then absolutely leave it to the pros (of which I am NOT). I am not certain you NEED to lower the motor to be honest...but for the extra 5 minutes it takes, I prefer it over inventing new curse words and busting up my knuckles more...
On the pulleys, the only other one you could swap is the tensioner/idler...The rest are all on something (like alternator, Power steering pump, etc..).
Interestingly on mine also, I read a bit online and heard many suggest that the Porsche pump was no bueno, and Gates made a better product (don't know the answer and not looking to start a debate here) but I decided to go with that one. When I went to install the belt, I realized the pulley was a little larger....I did a little math and used the circumference of the old and new etc...and went to Advance and got the right length and fit perfect....Just an FYI if you get a different brand...I was perplexed for a bit, as to why the belt I removed would not go back on
DC
Old Jan 22, 2018 | 08:18 AM
Johnny DB's Avatar
Can anyone confirm of Porsche has gone back to a plastic impeller??
Old Jan 22, 2018 | 09:32 AM
The Bogg's Avatar
It is composite. At least on the Pierburg (OEM supplier) version
Old Jun 22, 2021 | 12:36 AM
norwegiancarguru's Avatar
norwegiancarguru is infamous around these parts
How many hours does this take for a "new to porsche hobby mechanic"?
Old Jul 23, 2022 | 08:22 PM
Robocop305's Avatar
Robocop305 is just really niceRobocop305 is just really niceRobocop305 is just really niceRobocop305 is just really nice
Hi, what’s the password to open the document?
Old Apr 8, 2024 | 04:15 PM
slm181's Avatar
slm181 is infamous around these parts
I know it's been a long time since this was created, but does anyone have a pdf version of this? The link is broken and I need to change the water pump on my 997.1 tt. Thanks in advance!
