Modded 997.2 at Shift Sector vs the Competition
Old Nov 3, 2016 | 01:38 PM
99Gdzra's Avatar
99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute
Wow Wow Wow!!! Very impressive. I'm going to a 1/2 mile event this next weekend here in Texas. I am honestly hoping I can run 150-155mph. I wanna be like you when I grow up. Man your car is fast.
Old Nov 4, 2016 | 10:21 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Originally Posted by IMI A
LB - love your vids.
A friend of mine with same 9e 28 power kit (basically GT2 hybrid VTGS and GT2 RS coolers) bolted on a stock engined manual 997.1 turbo car up against a similar tuned PDK gen 2 turbo i.e. meth + zorst + tune.
Race is over 1.3 miles so LB can see what would happen on a longer run
The gen 2 cars are insanely fast. You need a real 800bhp in a gen 1 turbo just to keep up and thats if you don't fluff your launch.
https://www.youtube.com/watch?v=-ooq...G1WVeD&index=1
Jesus that was insane!!! The PDK setup is extremely efficient.
Old Nov 5, 2016 | 05:27 PM
akunob's Avatar
akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !
Great runs Adam, as usual. You crushed the field. Have you dyno'ed your car recently? I suspect it's putting out more power than you might expect.
Old Nov 7, 2016 | 12:15 PM
longboarder's Avatar
Originally Posted by OhSoCal
So you're saying the 997.1 has better top end? ...and this is referring to the aftermarket turbo 997.1's?
Yes - my last run in the vid.
My friend - you just need e85 and a custom tune and it will transform your 997.1. I bet you will keep up with those pesky .2's
Love those vmax 1.3 mile events.
Haha so how did you do?
I have to imagine the 911 Turbo PDK is the most efficient/effective driveline in the world. I just out launched a 918 twice this weekend. Held him off into the triple digits. Will get vids up on that shortly
Well it's just that I dyno on a low reading mustang. I'm at the limit of the stock fuel system. So whatever that power level is...that's where I'm at. I would guess something a little north of 700 crank.
Old Nov 8, 2016 | 11:36 AM
Thunder915's Avatar
Thunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond repute
In terms of performance per dollar spent hard to beat a PDK 997 turbo. Maybe a GTR perhaps but they cost a bit more to run.
Having watched LB for a while I knew the PDK turbo had this sort of power from just a simple flash, zorst and meth over a long run. The PDK 997 turbo ES 650 in the vid above running a GPS verified 0-300kph in 21 secs is simply amazing. I think LBs turbo would match it blow for blow. ; )
What's your friend 0-300kph?
Also keep in mind that Adam raced that built tranny 997.1tt from rolling not standstill.
Old Nov 8, 2016 | 12:34 PM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
That car definitely hits in a higher weight class. I was also impressed how hard the GT3 RS at 6:00 launched.
Old Nov 8, 2016 | 10:39 PM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
is it the 9e28 the camera car?
Old Nov 9, 2016 | 04:21 AM
yes 9e 28 gen 1 camera car v ES 650 gen 2 PDK.
this is weird how the manual car won at low gears and PDK at high gears.
Old Nov 9, 2016 | 05:57 AM
iLoX's Avatar
iLoX is infamous around these parts
The PDK wasn't using launch control or Sport Plus on this run...
Old Nov 13, 2016 | 11:49 AM
Actually it's interesting you say that because a friend from the UK was able to get my vBox from Shift Sector and compare against Adrian's vBox from vMax. Our stats are nearly identical.
My car tended to get out of the hole quicker and was faster zero-any speed. But in the triple digits Adrian's car was a little quicker. Obviously there are a lot of variables to consider like density altitude, wind direction and speed, etc. The results were probably the way they were because I was seeing 90+ degree F conditions and Adrian was seeing much cooler temps. The hot conditions allowed my tires to grip better on the launch but perhaps robbed a little HP on the top end. The colder conditions for Adrian hurt his launch but let the car remain cooler for longer.
Same day same place I bet we would be dead even or real real close.
