tire size variance on my 997.1TT?
Old Nov 2, 2016 | 04:26 PM
zmw's Avatar
zmw
zmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to behold
Any good guidance on how much variance is tolerable between front and rear?
235/35 and 305/30 19s are almost a full inch in diameter difference
GT2 fitment 235/35 and 325/30/19s are 1.2" difference in diameter.
Old Nov 3, 2016 | 12:20 PM
JF22's Avatar
JF22 is a jewel in the roughJF22 is a jewel in the roughJF22 is a jewel in the rough
don't look at inch look at % 235/35 and 305/19 difference 2.9% ...... 235/35 and 325/30 difference 4.7% not very good for 997tt
Old Nov 4, 2016 | 03:20 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Also remember GT2s are 2WD (RWD). I would not go over a couple% difference.
DC
Old Nov 4, 2016 | 08:01 AM
Webspoke's Avatar
Webspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond repute
The front and rear final drive gears are 3.3% different. So you have some leeway, maybe .5% for tire wear. The front drive clutch can allow some slip, running in sport mode also engages the front drive much less.
Old Nov 5, 2016 | 03:30 PM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Keep in mind the front and rear gear ratios are different in the 997 Turbo. Most people forget about this.
Final drive - rear 3.44
Final drive - front 3.33
Or about 3.3% difference. You actually need a 3.3% taller tire in the rear to make them perfect.
Co-incidence that Porsche uses a 305/30/19 and a 235/35/19 from the factory? That's a 2.7% difference and is on the edge of what most people recommend - but in reality it's only .6% when you account for the final drive ratio differences.
GT2 style fitment of 325/30/19 and 245/35/19 have a 3.5% size differential, however once you subtract the final drive differences you end up with an effective .2%. difference. That is as close as it gets ...
