997.1 turbo oil leak ?!
Old Nov 11, 2016 | 04:59 PM
977ttblue's Avatar
977ttblue is infamous around these parts
Today I noticed that the passenger manifold is fully coated with like an old oil, but the driver side nothing top of it, is that because the oil tank located in the passenger side and the leak reached the passenger manifold ?
Anyone has this issue before ?
Old Nov 12, 2016 | 07:16 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Put the car up on a lift and run it. Could be just a turbo line leaking or something simple like the valve cover leaking. It's unlikely that your case or heads have sprung a leak, probably a simple fix. A main seal behind the clutch is another likely possibility.
Old Nov 13, 2016 | 06:50 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Who did your last oil change? Possibly overfilled? Do you get smoke at startup?
Old Nov 13, 2016 | 10:18 PM
977ttblue's Avatar
No smoke at start up , porsche dealer filled the car
Old Nov 13, 2016 | 11:27 PM
brnrdtns's Avatar
Maybe something obvious? Check that the oil filter cap is tight.
Old Nov 13, 2016 | 11:33 PM
977ttblue's Avatar
Yeah you are right maybe the cab I will check it
