Issue after installing plenum
Old Nov 21, 2016 | 08:11 AM
superslow's Avatar
superslow is infamous around these parts
I installed an IPD plenum/ throttle body a week ago and am having issues blowing the throttle body- y pipe coupler off, or the plenum- intake hose off under full boost.
Has anyone had similar issues? I have fully installed/ uninstalled everything 3 times now and the same issues persist.
Thanks!
Old Nov 21, 2016 | 08:20 AM
3llooi's Avatar
3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !
Try cleaning the boot and TB and Ypipe with alcohol to ensure no dirt or oil residue exist
then may be consider changing the clamps??
Old Nov 21, 2016 | 08:22 AM
superslow's Avatar
Thanks for the reply. Everything has been cleaned and is in good shape.
Old Nov 21, 2016 | 09:08 AM
rob.boost's Avatar
rob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond repute
did you use an IPD coupler? It will have the lip on the inside of the coupler that will mate with the throttle body and Y-Pipe. I just installed mine this last weekend and haven't had any issues with it.
Old Nov 21, 2016 | 09:38 AM
wrxman60's Avatar
wrxman60 is infamous around these parts
You absolutely should get rid of the stock worm gear clamps and upgrade to good stainless steel band clamps for a better clamping force. You'll need a 4" clamp (for the TB) and a 4.125" clamp (for the y-pipe)
Old Nov 22, 2016 | 05:09 PM
Realife's Avatar
Realife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud of
rob.boost is right, with the IPD coppler and good quality clamps you can boost over 30 psi with no issues at all.
Old Nov 22, 2016 | 06:09 PM
Its important to make sure the angle of the IPD is even with the Y pipe- classic mistake on the 996s....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
