Testing for coolant leakage before installing motor
Old Jan 13, 2017 | 01:33 AM
bsh's Avatar
bsh
bsh is a name known to allbsh is a name known to allbsh is a name known to allbsh is a name known to allbsh is a name known to allbsh is a name known to all
Hi,
I have replaced the 3 plastic flanges, most of the coolant hoses and pinned the coolant lines. I have now blocked the engine coolant system and will pressure test the coolant system at 1 bar/15 psi before installing the motor in car. Better to discover leaks now while they are easily accessable...
Should I fill the engine with water before testing or can I just do it without? I was thinking air is very "thin" vs water and maybe it will show a "false" leak that would not have occured with "thick" water in it...?
How long should I pressure test it?
Old Jan 13, 2017 | 01:40 PM
32krazy!'s Avatar
i would use water since it will bubble with pressure and you might not see it with air. shouldnt take long to see if theres any leaks
Old Jan 13, 2017 | 04:07 PM
bsh's Avatar
bsh
Hi,
Yes you are correct. There was a tiny leak, but could not find it with only air. Filled with water and I could see some drops leaking from my blocking device...
Fixed now and pressurised to 1.0 bar. Have been holding pressure now for 2 hours. Will hold it pressurised over night and check in the morning.
Fingers crossed...
Old Jan 14, 2017 | 02:36 AM
bsh's Avatar
bsh
It has been holding pressure for over 12 hours now, so I suppose it is ok.
Old Jan 14, 2017 | 06:55 AM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Holding pressure that long is definitely good to go
Old Jan 14, 2017 | 11:09 AM
bsh's Avatar
bsh
Yes I just released pressure after about 22 hours and was still holding fine. Should be ok
