Hello guys, first of all excuse me if my English is not on point, it is not my main language. The story: I came across a classified with a set of two front calipers and two ceramic rotors in 380mm from a 997.2 GT3 RS in what apears to be a good deal, 2000€.
If I'm not mistaken, Porsche sells an adaptor which I can use to fit this calipers to my 997.1 Turbo which currently has 350mm steel rotors and red calipers. Here is the car:
I would like to ask you guys what do I need in order to make it work; if there are other parts that I must buy (master cylinder, hoses etc...) and if you can give any advice on what to look for to check if everything is okay with the rotors, calipers and pads.
Here you have some photos of the parts, do they look legit?
Well I found the information for myself. The Calipers are perfectly compatible but the rotors of the GT3/GT2 are different in offset to the Turbo ones, so they won't fit.
