Electronics in the Passsenger Side Door Not Working..
All Lights in the Passsenger Side Door Not Working..
I have a strange issue that I've just noticed. None of the lights on the passenger side door are working. My courtesy light, door sill light and window switch illumination are not working on my passenger side door.
The window works as normal and the footwell light works...but not the courtesy light, door sill light and window switch light.
I checked all the fuses in the footwell panel of the driver's side and they all look good. I'm completely baffled...any suggestions?
Thanks in advance
Thanks in advance
Hi Grey. Any water issues? Sounds like a ground/short issue. If the fuses check out OK it could be corrosion at the ground or maybe a relay. I had an old Honda that had this issue. Window was mistakenly left open during a rain storm and developed similar symptoms. In that case it turned out to be a ground for the wiring harness going into the door. I filed down the rust and it fixed the problem.
Good luck in your search.
The window does dip so the micro switch works. I didn't know there are two of them..where are they located? Maybe one works but the other doesn't?
