997.2 intercoolers diy
Old Apr 2, 2017 | 07:46 PM
Slategery997turbo's Avatar
Slategery997turbo is infamous around these parts
Use knife to score the tabs off run it a few times and
Then bend it off with a pliers
Cut away with knife around the trim un till it's flat
It should look like this when your done
Then put together and trim notches so it fits in you will
See once you tri to snap it together
Trim here too
This is what it should look like once you trim around it
Then reassemble then
