Pdk ok Dyno
Old Apr 26, 2017 | 05:56 PM
LOGANXXX's Avatar
LOGANXXX is infamous around these parts
Pdk ok Dyno
Hello there my friends,
i'm having a issue when testing my car ok the Dyno.
In manual mode, when i hit the pedal no 5th gear, it downshifts automaticly to 3rd gear.
I can't get an accurate measurement with that.
Is that any trick to get this done without this automatic downshifting?
The Dyno is a 4wd Dimsports. Pdk on Sport Plus and pcm Off.
thanks for any input!
cheers
Old Apr 27, 2017 | 09:12 AM
gogoevo's Avatar
gogoevo is infamous around these parts
This sounds like whomever is performing the dyno test is engaging the "kick-down" switch on the floor?
Old Apr 27, 2017 | 11:50 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
cheers
tbe best way to do it is you press the peddle 80% , so It do not shift down !!!! after you reach the 5500rpm , press it 100% !!!
Thats the the only way I found to test the PDKs Pcars on the Dyno
Old Apr 27, 2017 | 01:32 PM
SamboTT@ByDesign's Avatar
Roll into it gently to 100% and do not hit knockdown. Make sure traction and everything is off.
